brake issue is driving me mad!!!
BrianP:
--- Quote from: telelogic on January 27, 2009, 01:40 PM ---
--- Quote from: brianp on January 27, 2009, 01:16 PM ---
--- Quote from: telelogic on January 27, 2009, 12:01 PM --- I need to be able to have my coaster brake as an option and no new school frames allow me to use a big enough sprocket to go with the 16t on my coaster tuffs.
--- End quote ---
What about using a smaller coaster sprocket on the back, which will allow you to use a smaller chainwheel?
You can get coaster sprockets down to 12T, so 33/12 is about the same as 44/16.
Brian :daumenhoch:
--- End quote ---
are you saying that I could replace the cog I got with my new coaster tuffs with a 12t one? if so where can I get these?
--- End quote ---
Yup, if it takes the standard suntour type of sprocket like mr fruit has linked above.
I've a 12T and a 13T here on my sets. (Have been toying with running a set of coaster tuffs on my new FBM for a laugh)
And I got mine at flatland fuel.
Here's the link:
http://www.flatlandfuel.com/index.asp?PageAction=VIEWPROD&ProdID=241
Pat'll sort you out. He's a good egg.
Brian :daumenhoch:
lazychubs:
i just modded a odysee one to fit my suntour hub
just filed the ones i didnt need off
and shaped the other 3 to fit the hub
so i have old skool cassette hub with 12 tooth gearing
telelogic:
stodgy thinks he may have found a new school frame that I can run a 44t sprocket on :D
fingers crossed, I'll let y'all know.
telelogic:
WICKED!!!!
The legend that is stodgy has found me a frame that ticks all of my crazy boxes!
New school with a coaster!
Lookout 1984, I'm coming back blow your tiny minds! >:D
BrianP:
just watch those fakies...
Bp.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
