976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 10:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Half-link chains question
Author Topic: Half-link chains question  (Read 1541 times)
HEYWOOD BMX
« on: January 30, 2009, 09:06 AM »
 :) I recently compared a Gusset half-link chain to a regular chain and aside from the links being a different shape,the size was exactly the same.Is this the same with all half-link chains or just this one?
Re: Half-link chains question
« Reply #1 on: January 30, 2009, 09:07 AM »
they just bend around a smaller rear cog better.
HEYWOOD BMX
« Reply #2 on: January 30, 2009, 09:16 AM »
   OK.  I`m sure one manufacturer advertised them as being able to give more precise adjustability in the rear dropout due to the shorter length,or is that just marketing bull?
Offline se-bmxer
« Reply #3 on: January 30, 2009, 09:21 AM »
no marketing bull there right more precise adjustability, i have them on both 20" and cruiser and are the best chain i've ever brought  :daumenhoch:
HEYWOOD BMX
« Reply #4 on: January 30, 2009, 09:57 AM »
 :) Not sure if I`m old/confused/cynical... must be just this one brand,`cos I`ve just compared them again and the side plate of each link and the centre to centre of each pin are exactly the same....
« Reply #5 on: January 30, 2009, 10:02 AM »
You're old and confused   :LolLolLolLol:
The size between pins must be the same. This is known as the pitch and it must match the sprocket and driver.
The difference is that a regular chain has an inner link, then an outer link and so on. A halflink chain has neither, or both depending on which way you look at it.  So if you want to lengthen or shorten your regular chain you need to add/remove 1.5 links at a time, but with a halflink you just add/remove a single link each time - so better adjustablility   :)
HEYWOOD BMX
« Reply #6 on: January 30, 2009, 10:07 AM »
 Cheers,that makes sense. :daumenhoch:
« Reply #7 on: January 30, 2009, 10:13 AM »
motomagII
« Reply #8 on: January 30, 2009, 07:21 PM »
two bob to the rescue again was just about to type an explanation too but ya beat me to it lol
