976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 05:28 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing crank and bb from 08/09 quad 24? help!
Author Topic: removing crank and bb from 08/09 quad 24? help!  (Read 2160 times)
tickz
« on: February 08, 2009, 01:36 PM »
Im currently swapping all the black stuff from a 24 quad dc to a white 09 quad 24 frame and vice versa! Ive completed everything else but the cranks are different on the 2 models (different spines) so I have to swap the two BB over as well, can someone tell me how to remove the BB,s??
cheers
dave
Re: removing crank and bb from 08/09 quad 24? help!
« Reply #1 on: February 08, 2009, 02:17 PM »
you say diferent spines?  are they both the same diametre though?  probably both 19mm so just swap the cranks over including the axles  :daumenhoch:
THIRSTYKIRSTY
« Reply #2 on: February 08, 2009, 03:27 PM »
 H A M M A
tickz
« Reply #3 on: February 08, 2009, 09:41 PM »
the 09 quad has a 48 spline and the DC has (lot less) probably 32ish, so I need to swap the axles over as well??
steve Beech TA
« Reply #4 on: February 08, 2009, 09:52 PM »
 yes what they are saying is:
The diameter is the same on both, the only diff is the splines. Therefore all you need to do is swap the spindles they should fit in each others bb  :daumenhoch:
dodger
« Reply #5 on: February 08, 2009, 10:12 PM »
if there both 19mm axles then get a mallet and give those puppys some loving ither one beaing will pop out while hitting it but it should be ok.
tickz
« Reply #6 on: February 09, 2009, 08:55 AM »
Right then! take off crank arms and smack the axle/spindle out with my nylon hammer??
Stop
Hammertime!
« Reply #7 on: February 09, 2009, 12:50 PM »
that's the kiddy!  should only take a little knock to get it moving then just pull out  :daumenhoch:
barge
« Reply #8 on: February 09, 2009, 01:07 PM »
HOw are you gonna save the centre spacer from falling?
I guess if it's in there, and it's been there a long time, it will probably just stay where it is long enough to tap the axle though?
Si
« Reply #9 on: February 09, 2009, 01:13 PM »
they do drop but not enough to lose it......the BB isn't that big.  when you refit the cranks you just hold the internal spacer with your finger and push the spindle in from the other side  :daumenhoch:
tickz
« Reply #10 on: February 24, 2009, 05:34 PM »
Got my Hamma on it and removed both but the bloody axles were a different diameter (by 1mm) so needed to remove the bearings also!
oddly I think both bikes look better with the kit swapped over? Let me know what you think??
Behold the Quad 09 with 08 DC quad kit!
And Thanks all for the Advice,cheers :)
Offline priv
« Reply #11 on: February 27, 2009, 03:45 AM »
i never fcuking thought of that god i'm thick
