976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 10:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PEREGRINE CRANK HELP!
Author Topic: PEREGRINE CRANK HELP!  (Read 3105 times)
« on: February 13, 2009, 06:27 PM »
Hello all. I need your help pls.
I've got a minty chrome peregrine crank but the cups and bolts are knackered (the anlun ones). Someone must have been a bit rough with the old spanner. I want to replace them with an alternative as getting the right cups nowadays will be impossible. This is for a show pony and won't be ridden by the way so I just need something that'll take the spindle.
Will the spindle of the peregrine crank fit in the redline cups, the sealed bearing ones? If I could get confirmation that they do, I'll buy a set and then I can finish building up my Haro.
Please help as want to get this build done asap.
Matt  :)
Re: PEREGRINE CRANK HELP!
« Reply #1 on: February 13, 2009, 06:33 PM »
Can you post a pic The Peregrine cranks I had, had a threaded spindle.
& I think I might have a BB set, but can't remember if I sold it  :-\
« Reply #2 on: February 13, 2009, 06:42 PM »
Chris, yep that's the one the threaded spindle :) Will get up a pic asap.
You out for beers next week?  :D
« Reply #3 on: February 13, 2009, 08:25 PM »
I was talking to Munners earlier about this, I might do, but I have to drop my car for a service at 18.00  :(
Where & what time is the meet  ???
sonic-1
« Reply #4 on: February 14, 2009, 12:22 PM »
pm the guy who wants to swap the sugino ct crank set up , they use threded spindle n sealed bearings
get him to find yer the bearing No off em . worth a try
Offline Gary72
« Reply #5 on: February 15, 2009, 08:41 PM »
I've got some redline cups that you can borrow to try. If you want send a PM and will get them out of the cupboard and give them to Cazbo :daumenhoch:
« Reply #6 on: February 15, 2009, 10:05 PM »
Ok I have a BB set but it's an open one  :)
steve Beech TA
« Reply #7 on: February 16, 2009, 07:36 AM »
Hi mate
I can take the RL spindle of my TA if you want and send it to you, so you can try it. The only thing is i will need it back as i have not got anything to replace it with but at least you can see if it fits. LMK  :daumenhoch:
« Reply #8 on: February 16, 2009, 08:46 AM »
The Peregrine spindle has different pattern, but might be worth a try
« Reply #9 on: February 19, 2009, 08:58 AM »
This is my peregrine spindle photographed from above. Any similarities lads with your own spindle/bottom bracket kits? This is the only thing holding back my Gen 1 build. Need a replacement bb cups to fit this peregrine spindle badly!  :-\
« Reply #10 on: February 19, 2009, 09:52 PM »
matt whats broke the cup or bearings
as theres a shop in grays opp there footy club that does all sorts of bearings
as got new ones for me freecoaster when they blew after a week
Offline stuntmaster
« Reply #11 on: February 19, 2009, 11:01 PM »
i always though you could use one piece bb with peregrine cranks .could be wrong tho and no access to my pairs of cranks to check
no1stuntmaster on instagram
Rooonga
« Reply #12 on: February 20, 2009, 10:49 AM »
Stuntmaster is dead right.
They definitely take a standard one piece cranks bottom bracket.
