976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 10:49 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  3 piece crank spindle
Author Topic: 3 piece crank spindle  (Read 2660 times)
Offline stu27
« on: February 21, 2009, 07:39 PM »
ive got some redline single pinch crank arms,dont know what year they are but what spindle will fit them?
they seem to need one with 10 fine grooves on it,if that makes sense
any help is appreciated :daumenhoch:
Re: 3 piece crank spindle
« Reply #1 on: February 21, 2009, 07:43 PM »
The New skool twin pinch bolt spindle will fit them  :daumenhoch:
Offline stu27
« Reply #2 on: February 21, 2009, 07:46 PM »
alright steve,ive tried them on a new twin pinch spindle and it dont match up,fatter spines on that one but less of them :daumenhoch:
« Reply #3 on: February 21, 2009, 07:51 PM »
Who's Steve  ???
I had sets of single & twin Flights & the spindles fitted each other  :-\
I'm confused now  :-\
Offline stu27
« Reply #4 on: February 21, 2009, 07:58 PM »
IM A DIV,sorry about that
do all redline crank arms fit all redline spindles regardless of year?could i be right in thinking they might not be redline
« Reply #5 on: February 22, 2009, 06:15 AM »
No I don't think they all fit each other, I'm not sure about the proline's, think I heard they might be 20mm.
But the Single Pinch from BITD & the New Skool Twin Pinch, I'm sure do.
Have you got a photo  ???
Offline stu27
« Reply #6 on: February 22, 2009, 09:44 AM »
they have 180 stamped by the pedal entry and ive tried to show the 10 fine grooves in the crank arm,would the spindle for this be easy enough to get hold of,once again any help is appreciated :daumenhoch:
« Reply #7 on: February 22, 2009, 10:29 AM »
Not sure they are Redline's mate  :-\
« Reply #8 on: February 22, 2009, 03:09 PM »
I'm not sure they are Redline either, do you have a pic of them side on?  Be interesting to see what the sticker indent looks like as usually the cranks length is stamped on the topside of each crank arm  :-\.
Having said that, there are two or three different spline patterns that Redline use, I have two sets of twin pinch cranks that have differing spline patterns  ;).
