976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 02:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  can you get cranks rethreaded ?
Author Topic: can you get cranks rethreaded ?  (Read 1997 times)
eloopnai
« on: February 25, 2009, 11:52 AM »
heres my new skool cranks funn hooka mx
 i have cross threaded the pedal and in time become loose and as you can see the thread has now gone
can this be repaired ? if so where does one get it fixed   ???
Re: can you get cranks rethreaded ?
« Reply #1 on: February 25, 2009, 12:14 PM »
you sure can ian......but i wouldn't know where to suggest you get it done....sorry  :-\
eloopnai
« Reply #2 on: February 25, 2009, 01:01 PM »
thats good news im half way there just gotta find out where now
cheers  :daumenhoch:
thecrooch
« Reply #3 on: February 25, 2009, 01:06 PM »
probably be cheaper just to replace.....
eloopnai
« Reply #4 on: February 25, 2009, 01:22 PM »
spoil sport  :(
its just an idea i had as there pretty much new and was on my harrys kuwi there 175 so thought i could get em repaired and painted gold for my build .
 a new set is only £55 plus the cost of getting them painted by dan
 so i wouldnt of thought it would cost that much to repair so id be quids in if i can find out where :D
« Reply #5 on: February 25, 2009, 01:29 PM »
i once got a Shimano XT drive side arm re threaded by a mate of mine.....worked a treat for XC riding but i wouldn't want to do any jumps or owt with it.
as Crooch said........have a look round and grab a new set?
Offline jT Racing
  • i like bikes. :/
« Reply #6 on: February 25, 2009, 01:33 PM »
if it's an ali crank, pick a pedal you like and trust and araldite(or other epoxy resin) the fecker in :LolLolLolLol:
ding dong
Offline diesel
« Reply #7 on: February 25, 2009, 03:49 PM »
I had one done at Halfords for £10
I wouldn't recommend it for riding after though - Just show
Offline SteveG
« Reply #8 on: February 25, 2009, 04:15 PM »
I was going to suggest a helicoil which is basically a spring looking thing that screws into a slightly larger tapped hole. I don't know if pedals are a special thread though.
Try a small engineering company they might be able to help.
If the helicoil doesn't work then they might be able to tap a larger thread in the arm and make a threaded bush up to bring the thread back to size.
It might be possible to get it welded and re-tapped if its something rare, but anything will end up costing a bit.
thecrooch
« Reply #9 on: February 25, 2009, 05:24 PM »
personally i agree this could work, but of all the stress areas on a bike you want confidence in is the pedals and having them re-threaded wouldnt give me that!
Ian there are plenty of cheap relacements knocking around.....  Think quad paul has a set out of his Haro 24.
Offline SteveG
« Reply #10 on: February 25, 2009, 06:07 PM »
If it's done properly a helicoil (if you can get the size) is better than just a thread in aluminium.
On a lot of aircraft stuff they are actually fitted to new parts. The same goes for the threaded bush. You would need to stick it in with proper loctite or make it so it screwed in from the back and had flats on it to hold with a spanner.
As you say though it isn't worth doing unless it's rare though as it will cost to get it done properly.
Offline jT Racing
  • i like bikes. :/
« Reply #11 on: February 25, 2009, 06:09 PM »
just epoxy the pedal in, it's strong enough. they use it to stick the wings on aeroplanes, and they used it to stick a bmx frame together, a vitus. easy peasy.
ding dong
eloopnai
« Reply #12 on: February 25, 2009, 06:35 PM »
cheers for the advice fellas think i will leave it and purchase some new ones
right then off to the shed to find some bits to sell  :daumenhoch:
fouronethreeoh!
« Reply #13 on: February 25, 2009, 06:41 PM »
Remember pedal threads are left and right hand. Finding an engineering shop with 9/16 left hand helicoils may be a bit tricky.
But not impossible. Pedal taps are available.
http://www.parktool.com/products/detail.asp?cat=27&item=TAP%2D6
Bushing the hole then re tapping is an option, similar to helicoiling.
Offline jT Racing
  • i like bikes. :/
ding dong
moanjam
« Reply #15 on: February 25, 2009, 09:52 PM »
helicoil defo be ok
