976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 03, 2026, 05:28 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stuck seat post
Author Topic: stuck seat post  (Read 1640 times)
LOS1969
stuck seat post
« on: February 25, 2009, 05:57 PM »
tryed wd40 and heating up still wont move,help help please :daumenhoch:
Re: stuck seat post
« Reply #1 on: February 25, 2009, 06:48 PM »
what bike, what post, pics.
Offline stfc
Re: stuck seat post
« Reply #2 on: February 25, 2009, 07:02 PM »
check this out , took me a few hours and soakings overnight  :) :)                                          http://www.radbmx.co.uk/forum/index.php'topic=80429.0
donnydresser
Re: stuck seat post
« Reply #3 on: February 26, 2009, 11:27 PM »
wd40  and a big hammer its just oxidides seen it happen wi cars wheels best to soak overnight  mate
Re: stuck seat post
« Reply #4 on: February 27, 2009, 03:49 AM »
Diesel rather than WD40  :daumenhoch:
ozone
Re: stuck seat post
« Reply #5 on: February 28, 2009, 10:17 AM »
This sounds daft but if you don't have a vice, try this - it definitely works.
After you have let the diesel or WD40 work its way down the seat tube, get an old stem and clamp it to the seat post.  Lay the frame on the floor so the shaft of the stem is vertical.  Get a piece of tubing or an old set of forks and slide it over the shaft of the stem, then start working the tube/forks back and forth (you need to stand on the frame to stop it moving so do it on a bit of carpet or something ::)).  Once you get the post moving, you should be able to keep turning the post right the way round and, with a bit more effort,  you should be able to turn it all the way out.
Using a stem doesn't usually cause a lot of damage to the post, so they can often be salvaged.
I don't have a vice or owt and I have used this method plenty of times...
