976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 02:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Can I totally strip a coaster hub?
Author Topic: Can I totally strip a coaster hub?  (Read 1808 times)
Daletsunami
« on: April 07, 2009, 07:04 PM »
I've got a suntour coaster hub that I am wanting to strip down for some work and wondered if I can fully strip it in order to make this easier.
Any advice?
Re: Can I totally strip a coaster hub?
« Reply #1 on: April 07, 2009, 07:10 PM »
yes you can, just remember how it came apart, it can pretty much only go back together one way.....
snav69
« Reply #2 on: April 07, 2009, 07:11 PM »
Daletsunami
« Reply #3 on: April 07, 2009, 07:55 PM »
Cheers for that :daumenhoch:
I have managed to get most of it stripped now and have drawn my own diagram on what goes where so I can put it back together but the brake lever is not going nowhere, is that normally the difficult bit?
mark 2
« Reply #4 on: April 07, 2009, 09:48 PM »
http://www.wtlw.net/ff/suntour/
 :coolsmiley:
That's well handy Snav, Dale they're a right bugger to put back together
adeshere
« Reply #5 on: April 08, 2009, 01:07 AM »
Just remember to put the pads in the right way around
subversion
« Reply #6 on: April 09, 2009, 11:21 AM »
I take it you mean the brake 'arm' which attaches to the chain stay of the frame? If so then this sits over the inner cone of the hub like a spanner would. You just need to hold it to undo the outer lock nut non drive side & it should just come off of the inner cone/race assy. Few taps with a rubber mallet will shift it if it's stuck :daumenhoch:
