976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 05:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Headset fitting
Author Topic: Headset fitting  (Read 1821 times)
Thejackal
Headset fitting
« on: April 20, 2009, 07:39 AM »
I need to fit a pair of headset cups to a frame that I have bought..............
Is this easy/ difficult/ hard?
What gear do I need?
Is it something an amateur can do? Or do I need to put my hand in my pocket, and let someone who knows what they're doing have a look? ;)
Bettyswallocks
Re: Headset fitting
« Reply #1 on: April 20, 2009, 07:42 AM »
Rubber mallet or hammer and a block of wood
Dont whack to hard and mind yer fingers...  :daumenhoch:
Re: Headset fitting
« Reply #2 on: April 20, 2009, 07:45 AM »
if you have never done one before and your frame is valuable then i wouldn't try yourself.  the proper tool is a press that lines up the cups properly and presses them into the frame, your local bike shop shouldn't charge more than £10 to do it for you?
i normally use the good old fashioned rubber mallet and a big block of wood......but i wouldn't try this if you've never done it before as you do have to really give em a whack!
telelogic
Re: Headset fitting
« Reply #3 on: April 20, 2009, 10:18 AM »
I took mine to a local bike shop who charged me £10 to put my head set & bb cups in.
took 5 mins' and meant that I didn't have to go hitting my precious with a hammer ???
look for a proper bike shop though, don't take it to Halfrauds or anything crazy like that!
Offline wildon
Re: Headset fitting
« Reply #4 on: April 20, 2009, 10:36 AM »
Halfrauds!!   :2funny:
Thejackal
Re: Headset fitting
« Reply #5 on: April 20, 2009, 12:41 PM »
Thanks all.
Is it a similar deal with the crank cups? In which case I'll get both done at the same time.
It would be fair to say, that mechanically, I am completely inept!! 8)
daz bmx it!
Re: Headset fitting
« Reply #6 on: April 20, 2009, 02:21 PM »
where do you buy the above? and how much? :daumenhoch:
daz bmx it!
Re: Headset fitting
« Reply #7 on: April 20, 2009, 02:28 PM »
Re: Headset fitting
« Reply #8 on: April 20, 2009, 02:30 PM »
or if there are a few of you that ride together, go shares on buying one....that way it'll be much cheaper and you can all use it  :daumenhoch:
Juju
Re: Headset fitting
« Reply #9 on: April 20, 2009, 08:52 PM »
Yuo can make your own out of a 3pc crank spindle  and a couple of big washers and nuts.
