976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 06:38 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Coaster brakes. What r they & do I need/want one?
Author Topic: Coaster brakes. What r they & do I need/want one?  (Read 2743 times)
g_lamb
« on: April 26, 2009, 09:49 AM »
Daft question I know but what is a coaster brake and what does it do?  :-\
Cheers all
Lamby
Offline Bigfrawg
Re: Coaster brakes. What r they & do I need/want one?
« Reply #1 on: April 26, 2009, 09:51 AM »
it brakes and stops you from coasting . pedal back and the rear wheel brakes .
telelogic
« Reply #2 on: April 26, 2009, 10:12 PM »
you want one!
they make you look all cool, like Fonzy :daumenhoch:
trasher
« Reply #3 on: April 26, 2009, 10:56 PM »
and great for skids  :daumenhoch:
g_lamb
« Reply #4 on: April 27, 2009, 07:17 PM »
OK  :LolLolLolLol:
What do i need?
telelogic
« Reply #5 on: April 27, 2009, 08:42 PM »
if you want some for an old school, era correct build, put a post in the wanted section or look on evilbay.
if you just want a set of new ones you can get them from a few different places.
I bought a new set last year from a UK vendor,( £110) but when I needed another set earlier this year I had to get some from the US, and that got expensive >:( (£160)
you could always just buy a 20" spoked wheel with a coaster brake from ebay, (there are always some on there fairly cheep) stick it on your bike and see if you like it.
do you have a build that you are thinking of putting them on?
g_lamb
« Reply #6 on: April 28, 2009, 01:18 PM »
Possibly onto an '84 torker with Tuff II's (Alloy hubs)
telelogic
« Reply #7 on: April 28, 2009, 01:34 PM »
I'm sure there was an alloy hub tuff II coaster wheel in the for sale section a little while ago (maybe only a week) Have a look, maybe it didn't sell!
the new ones are only available in pairs unfortunately, you're probably better of getting an era correct one for your build anyway.
a wanted post should pull one out of the closet fairly quickly.
what colour tuffs do you have?
adeshere
« Reply #8 on: April 28, 2009, 10:25 PM »
A coaster brake is a brake built in to the rear hub.
When you pedal backwards, it causes the brake in the hub to lock, causing the wheel to stop moving.
If the bike is moving backwards and you dont try and pedal backwards, the bike will move backwards without the pedals(crank) moving backwards too .. like a freewheel would
Offline Faze7-Ade
« Reply #9 on: April 28, 2009, 10:31 PM »
Cheers all
Lamby
We used coaster brakes BITD for tricks which needed the back wheel locked with your hands off the handle bars - like no hander kick turns, & bar spin kick turns. They are also good for 540 kickturns where the caliper brakes slip a bit. Also good for roll backs because with the pedals level you can roll for ever without pedaling. Great for dropping in on a quater pipe because you put your weight on the back facing pedal, so you can hold the stall for longer.
And yes they are good for skids....... ;)
But be careful, they take a bit of getting used to  :daumenhoch:
adeshere
« Reply #10 on: April 28, 2009, 10:37 PM »
Number of times i went over the handle bars going up curb's as when you pull up the bars you lean back and the back wheel locks. leaving the bike where it is and you keep going
electobooty
« Reply #11 on: April 28, 2009, 11:20 PM »
tbh if you are of the more mature persuasion, as most of us are, if you didn`t use one bitd i would stay well clear now, they take some getting used to  :-[
Offline HARORIDER
« Reply #12 on: April 29, 2009, 12:45 PM »
yeah i agree i could never get on with them :yahoo_silent:
g_lamb
« Reply #13 on: April 29, 2009, 09:32 PM »
Thanks all
Think I'll stick to what I know and that's no coaster brake  ;)
@ telelogic: Red Tuff's
