Oldschool Frame with N/S forks ?
oldschool rider:
Cheers Dan I will do, it's not for me it's for a mate here I will pass the message on.
Steve.
spinmaster:
i've done this recently after seeing someone on here did it. can't find the thread but basically i put tioga beatrap 2 cups in the old frame got a unsealed 1 1/8th headset, took the bearings out of the cages, loads of grease in the cups, bearings in then used the rest of the 1/18th headset to finish off.
will look for the thread.
fugazi:
You also need to watch which cups you use as some of the more heavy duty jobbies wont allow the larger steerer tube through, beartrap 2 cups work well :daumenhoch:
spinmaster:
yep i was told beartrap 2 cups would be best.
here's the thread i got the idea from
http://www.radbmx.co.uk/forum/index.php'topic=72502.0
oldschool rider:
:daumenhoch: Cheers for link to thread, I knew I had seen one somewhere.
Steve.
Navigation
[0] Message Index
[*] Previous page
Go to full version
