976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 03:13 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Very quick question
Author Topic: Very quick question  (Read 1755 times)
dannywhiteley
Very quick question
« on: May 11, 2009, 08:06 PM »
Are these standard sized chain ring bolts?  I.e. Will they fit a power disc and chainring?  They are labelled as 'double' sized.
« Last Edit: May 11, 2009, 08:09 PM by dannywhiteley »
fouronethreeoh!
Re: Very quick question
« Reply #1 on: May 11, 2009, 08:13 PM »
Short answer, no.
Double ring bolts are too long and dont clamp up single ring/spider.
They can be "adjusted" to work if you are a bit handy with a file.
dannywhiteley
« Reply #2 on: May 11, 2009, 08:25 PM »
Or a hacksaw?  Could you take a few mm off each one to enable them to tighten up a single disc and ring?
fouronethreeoh!
« Reply #3 on: May 11, 2009, 08:29 PM »
Yes, just shorten the nut part, not the bolt  ;)
trasher
« Reply #4 on: May 11, 2009, 08:52 PM »
ill let you know danny ,,i bought some of the bay last night  :bondage: :daumenhoch:
Juju
« Reply #5 on: May 11, 2009, 08:53 PM »
I suppose you could, if you had lots, pack the bolt head side out with little washers...
ok, it was a silly idea.... but the initial reply is correct, single ring bolts are what you need. Not thateasy toget unless you lbs is into "singlespeed and fixies".  Or old school bmx. When I went into my lbs asking for bolts for a spider, they looked as if I'd walked off the set of Ashes to Ashes, the kids lolled and said BMX haven't come with seperate spiders since they were born, basically......
I left feeling very old indeed.........
trasher
« Reply #6 on: May 11, 2009, 08:59 PM »
p.s this was in the listing i bought off
 These are suitable for double chainrings, single ring and bash ring or the two outer rings of a triple.    :-\
dannywhiteley
« Reply #7 on: May 11, 2009, 09:18 PM »
Looks like you could either cut down the nut part a few mm, or use standard nuts off a regular set (they arent that visible anyway).  The bolt part would extrude slightly out the back, but nothing really to worry about.
gossa
« Reply #8 on: May 11, 2009, 09:58 PM »
Yep they are a bit too long but very soft alloy so just file em down, shouldn't take a minute.  It would be much more difficult to saw them, got a dremel or a bench grinder?
dannywhiteley
« Reply #9 on: May 11, 2009, 10:01 PM »
Can get my dremmel on the job... :D
Love a bit of BMX DIY.  Its too easy when things fit first time anyway... :LolLolLolLol:
gossa
« Reply #10 on: May 11, 2009, 10:17 PM »
alloy chainring bolts are so soft you could probably chew them down!
