976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 09:52 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile bearing tube spacer question
Author Topic: Profile bearing tube spacer question  (Read 1438 times)
JT71
« on: May 19, 2009, 07:40 PM »
what are the two lenghts?
I assume that the one in my DK was the right length but when i changed the bearings the one i had was too short.
i think i need one about 50mm, but when i cut a piece of seat tube to make one it came out a touch too long.
so i'm going to buy one but need to know what the lengths are for the gold and the silver ones.
GREMLIN
Re: Profile bearing tube spacer question
« Reply #1 on: May 19, 2009, 07:46 PM »
I have a Gold one here and it measures 52mm.  :daumenhoch:   G.
JT71
« Reply #2 on: May 19, 2009, 07:52 PM »
cheers dude
Offline BrianP
« Reply #3 on: May 19, 2009, 07:59 PM »
Hey JT,
Just dug up this info online:
Gold one is: 2.035" - 52mm as Gremlin says ^^^
Silver one is: 2.185" - 55mm
Brian  :daumenhoch:
JT71
« Reply #4 on: May 19, 2009, 08:10 PM »
awesome info, cheers dude, my measure must be out, i'll get a gold one.
thanks again.
Offline BrianP
« Reply #5 on: May 19, 2009, 08:25 PM »
This is strange tho... that info was lifted off the profile website shop (crank spares) but i just went out to look in my box of bits, and i've a spacer tube here out of a mid bb set (it's black) which is only measuring 44mm  ???
Is it a mid or us bb you're setting up?
PM me ur addy if you want this one, just in case, and i'll get it out to you tomorrow.
If it's a wee bit short you could add some washers inside the BB shell as well.
Brian  :)
