976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 01:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SEAT RESTO PROBLEM.
Author Topic: SEAT RESTO PROBLEM.  (Read 2293 times)
Offline PRO THUNDER
  • Wanted. Huffy Pro Thunder bikes and parts.
SEAT RESTO PROBLEM.
« on: May 25, 2009, 09:41 AM »
THIS HAS PROBABLY BEEN ASKED A DOZEN TIMES BEFORE.  I HAVE GOT A KASHIMAX SEAT WHICH HAS GOT ONLY SOME SMALL SCUFFS.  I HAVE SANDED IT WITH FINE
PAPER AND IT HAS COME UP OK, BUT WERE I'VE SANDED IT,  IT HAS LEFT A DULL MATT TYPE FINISH. IS THEIR ANYTHING I CAN IE: POLISH OR BLING IT UP WITH.
Re: SEAT RESTO PROBLEM.
« Reply #1 on: May 25, 2009, 11:34 AM »
Offline PRO THUNDER
« Reply #2 on: May 25, 2009, 12:28 PM »
Cheers Marty :daumenhoch:  Anymore suggestions? ???
« Reply #3 on: May 25, 2009, 12:53 PM »
Honestly, try it I used it to restore my Kashimax Aero and it removed all the light scratches around the lettering and left it glossy and new again  :daumenhoch:
Offline PRO THUNDER
« Reply #4 on: May 25, 2009, 01:16 PM »
OK, thanks for that, but the scratches are on the top of the seat were it isn't glossy. Both sides are scratch free. will this stuff still work? ::)
mark 2
« Reply #5 on: May 25, 2009, 03:40 PM »
Marty you big tiger, do you reckon it would polish out scratches on clear acrylic lids on record players?  :-*  Anything in it that would colourise the clear........?
Yakky da
* I've read it properly now, sounds like it would be just the ticket *
Plast-RX Clear Plastic Cleaner & Polish
This easy to use, rich gel formula quickly restores optical clarity to both rigid and flexible clear plastics. Cutting-edge advancements in Meguiar’s exclusive Microscopic Diminishing Abrasive Technology (MDAT) easily removes oxidation, chemical degradation, contamination, stains and light surface scratches. Plast-RX also contains long lasting durable protection to keep your plastics clear and beautiful longer. Plast-RX is non-toxic and does not contain harsh solvents.
« Last Edit: May 25, 2009, 03:42 PM by mark j. »
Offline PRO THUNDER
« Reply #6 on: May 25, 2009, 04:15 PM »
Cheers for that. :daumenhoch: i'll go puuurchase some.
gadd
« Reply #7 on: May 25, 2009, 04:58 PM »
My kashimax seat was dull so i sprayed it with WD40 in a bag and left it for a bit, turned out ok
Offline PRO THUNDER
« Reply #8 on: May 25, 2009, 05:45 PM »
AH. I'VE GOT LOADS OF WD40.  I'LL GIVE THAT AGO AS WELL. :daumenhoch:  ANYTHING ELSE??  ::)
« Reply #9 on: May 26, 2009, 03:04 PM »
lol i just spray painted mine..............................and no i aint kidding  :D.
come out ok for a show bike.
Offline stevochb
« Reply #10 on: June 09, 2009, 09:55 AM »
does any one know if t-cut works?
daz bmx it!
« Reply #11 on: June 09, 2009, 10:22 AM »
Auto-glym bumper gel will bring the shine back up and the Neilsen bumper gel is even better! but they dont take scratches out ;) but as a colour restorer work excellent! ;)
Offline 20to26
« Reply #12 on: June 11, 2009, 07:44 PM »
I tried Tesco Tyre & Bumper restorer and it brought out the black quite nicely for £4.99
Every little helps.
