976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 05:37 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Head set problem!!
Author Topic: Head set problem!!  (Read 2382 times)
buzzlightyear05
Head set problem!!
« on: May 29, 2009, 02:42 PM »
Ive just been down to the Lbs  and bought a Tempory Inch headset to stop me knocking the forks out of a frame.
Anyway i run off to the shed to fit said head set and it falls into the frame  :crazy2:
It says 1' on the box so i presumed it should fit fine,Ive treid an 1 1/8 cup and thats not going in.
does anyone know if you can get headsets smaller than 1'??? Everything screws fine onto the forks ect just the cups.
Anyone know what the scrore is,before i convince myself im a bit :idiot2:
Tom.
Re: Head set problem!!
« Reply #1 on: May 29, 2009, 02:46 PM »
No not as far as I know, sounds like the frame is bigger  ???
lodge
« Reply #2 on: May 29, 2009, 02:48 PM »
What frame is it?
buzzlightyear05
« Reply #3 on: May 29, 2009, 02:51 PM »
Its an 83 Kuwahara Nova. Its making my head hurt now lol.
GREMLIN
« Reply #4 on: May 29, 2009, 02:54 PM »
I sourced a cheap and nasty 1" Diamondback headset from Halfrauds a few years back to fit a frame and fork set together so I could sell it.  :idiot2:
The cups literally fell into the headtube and rattled around.
Even tho the beartrap headset i removed had fitted perfectly, and the Nikyo headset I finally used fitted perfectly too.
So I'd say the cups may be at fault.  :daumenhoch:   G.
Offline Bigfrawg
« Reply #5 on: May 29, 2009, 02:57 PM »
i have had the same problem , i think sometimes the cups are just different sizes  :-\
moley
« Reply #6 on: May 29, 2009, 03:00 PM »
1" threaded Headset for BMX's is different to other 1" Headsets.
Some early Burners had a smaller Headset (I think)
Your Headset is probably for a smaller 1" sized headset!!
http://www.sheldonbrown.com/cribsheet-headsets.html
buzzlightyear05
« Reply #7 on: May 29, 2009, 03:01 PM »
Cheers guys! The cups it is then lol. Im gunna go try use a bit (ALOT) of tape to fill the 4mm gap :tickedoff:
Offline Bigfrawg
« Reply #8 on: May 29, 2009, 03:03 PM »
4mm gap !! :shocked: i'd try a different headset if the gap is that big dude .
moley
« Reply #9 on: May 29, 2009, 03:05 PM »
try another BMX headset!!
You've probably bought a 1" girly bike headset!!  :LolLolLolLol:
buzzlightyear05
« Reply #10 on: May 29, 2009, 03:07 PM »
lol its only to keep the forks in place for the time being save me knocking them over all the time. It will get replaced when i build her up dont worry.
Teaches me for buying £4 girly bike CRAP lol.
moley
« Reply #11 on: May 29, 2009, 03:21 PM »
Measure your headtube internal diameter and check it against the sheldon list!!  :daumenhoch:
« Reply #12 on: May 30, 2009, 06:44 PM »
all my streetbeats had this problem too  :D.
« Reply #13 on: May 30, 2009, 06:53 PM »
a mtb 1"headset is smaller as i have one in me shed hatta sealed aswell
