976297
lemus
June 21, 2026, 12:41 PM
Redline Prostyler decals
Topic: Redline Prostyler decals (Read 3586 times)
Redline
Cherry Picker
February 24, 2006, 12:01 PM »
Can anyone help me to get hold of a Redline Prostyler sticker set.... the one I bought on ebay are like totally the wrong size? I've just joined this website and not sure if this is where I ask for stuff like this?
diesel
Look Back
Re: Redline Prostyler decals
February 24, 2006, 12:36 PM »
Did you buy a set of Redline reproduction decals?
If so you can use them but you'll have to cut them down a bit to fit.
For the down-tube you'll need to cut the decal on the very edge of the 'E' on the other side the 'R' and if I can remeber correctly take out about 7cm of the remaining black area before the grey stars.
Then join them back up as you apply them to the frame.
The same with the seat post and the fork decals I think, its been a while since I did this one.
Best of luck, you will need to do this as an original set will set you back £100 plus if you can find any.
Last Edit: February 24, 2006, 12:38 PM by diesel
Mattdub
Site Supporter
BMX Overlord
February 24, 2006, 02:27 PM »
Hey Dan ,
Do you know anything about Redline Serials ? , I've got RE 00719 ?
Matt
diesel
Look Back
February 24, 2006, 03:33 PM »
Here you go:
RE***** = 1985
RD***** = 1984
RC***** = 1983
RB***** = 1982
RA***** = 1981
1985!
Redline
Cherry Picker
February 24, 2006, 05:11 PM »
Thanks Mr Diesel.... think I'm going to have to produce a new set myself.... I'm too much of a perfectionist to be cutting and pasting incorrect stickers.
baldbmxer
February 24, 2006, 08:02 PM »
There was someone around Wakefield who had some reproduced. I got some, they dont have to be cut dont and they were quite good althought the registration of the coloured was slightly out.
Cnt remember his name though....... sorry! But you could put a post up and see if he gets in touch or if anyone else knows him.
Cheers JJ
subwax
February 25, 2006, 10:36 AM »
RE is 1985, making it the 2nd generation Prostyler. Should have pegs in the forks and Peregrine mags.
NOS decals are still available, guys - email azbicycles@aol.com. Kay will sort you out a set. Pls tell her Neil sent you.
Neil
Mattdub
Site Supporter
BMX Overlord
February 25, 2006, 05:21 PM »
Mine must be 84/85 then if that lettering id is correct , it has non peg forks.
diesel
Look Back
February 25, 2006, 05:44 PM »
I'm pretty sure that the peg forks came out on the late 85/86 model, the forks that I used for my build did not come with the frame and therefore were probably not era correct, But trying to find a set of Redline forks for the 5" headtube was next to imposible at the time.
subwax
February 27, 2006, 03:57 PM »
For those decals, its either an 84 or an early 85 - the pegs came on the late 84 and early 85 bikes. After early 85, the decals changed to the 85 RL20 II syle decals, and then onto the 86 decals.
diesel
Look Back
February 27, 2006, 05:11 PM »
I would think you right Sub!
I just used what I could get
Zippy
900 Air
Reply #11 on:
February 27, 2006, 07:17 PM »
that frame is from my all time favorite bikes.
