976297 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 11:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing Turbo Crank Drive side from spindle
Author Topic: Removing Turbo Crank Drive side from spindle  (Read 1800 times)
FuNMoNsTeR
« on: February 24, 2006, 12:28 PM »
Super Noob here again with another one for you all ;D
Ok i have removed the spindle bolt on the drive side as you can see. I have had the crank puller on it and despite developing an extra testicle i cannot get the spindle out of the Drive side crank arm. Is there something else stopping it or should it come off with more force or a sharp smack.
 Once i get the spindle out i can remove the spyder and sand it and remove the bearing race and clean it and the spindle.
Thanks Guys...
Offline diesel
Re: Removing Turbo Crank Drive side from spindle
« Reply #1 on: February 24, 2006, 12:39 PM »
I had a metal worker press mine out on a big machine!
Offline ORB
« Reply #2 on: February 24, 2006, 12:44 PM »
yip
more beef is the answer
12
FuNMoNsTeR
« Reply #3 on: February 24, 2006, 12:50 PM »
I will give it another go with more leverage(i will get the wife to nag it whilst i heave)
 If it still wont go i will take it to the gentle giant who removed my pedals for me :)
thanks guys :daumenhoch:
Offline sawzall
« Reply #4 on: February 24, 2006, 01:24 PM »
i took my crank arms off yesterday the non drive side came off a piece of piss but the drive side was stuck like yours, i used oxy and accetylene gas bottles in the end .put old bolt in shaft and wind in leaving enough of a gap to fit nozzle then warm up little at a time (dont get to hot because of alloy spider) i put arm across vice and tapped with a hammer on bolt and after a couple of goes i came out i think heat will be better than force as i have seen shafts break!!!
FuNMoNsTeR
« Reply #5 on: February 24, 2006, 04:30 PM »
Plus Gas and crank puller......Its out :D
I nearly broke my shaft pulling on that crank tool too ;D  Ooooh me plums :o
Whole thing is stripped... spyder is now sanded. Bearings will join the pedals in Alans deep oil bath.
I should have it rebuilt by next week.... :-X
Cheers Guys...
