976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 03:46 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DX Pedals - getting pins out!!
Author Topic: DX Pedals - getting pins out!!  (Read 2113 times)
bigsman
« on: June 12, 2009, 04:42 PM »
I need help(!)  Got most of the old pins out of my dx ok but theres a few left that are too short to get hold of and I'm buggered if I know how to get these bams out!  Drilling seems like a shout but its murder trying to get a start on a round/pointy shaped end with a hand drill ...ok they can be sanded but they're pretty tough little feckers so has anybody got any handy tips as to how to get these out without resorting to a machine shop?
Offline sawzall
Re: DX Pedals - getting pins out!!
« Reply #1 on: June 12, 2009, 07:10 PM »
drilling is your only option,grind or file pin so it is flat then centre punch pin and drill first using a really small drill bit then go up in size so it's almost same size as pin,this should clear out old pin without touching any of the pedal :daumenhoch:
bigsman
« Reply #2 on: June 12, 2009, 07:35 PM »
Cheers bud it does look that way  :'(  I've got 5 to take out...per pedal!  First attempt didn't go well....drill bit went clean through the pin....and the pedal then snapped :'(.  SLowly slowly catchy monkey on the 2nd and it's going ok but man this is no fun!
Offline graeme
« Reply #3 on: June 12, 2009, 08:01 PM »
If you can get hold of the pins at all, you could try putting them in the oven.
Aluminium expands quicker than steel so the pins may get looser.
JT71
« Reply #4 on: June 12, 2009, 08:11 PM »
are you getting em re-anodised?
if so don't worry, cos they'll come back with the pins miraculously gone...just ask Greg (Rox)
bigsman
« Reply #5 on: June 12, 2009, 08:16 PM »
Nah not enough pin to get a grip on unfortunately and no not re-annodizing either.  DIY restoration job here... was going great til this point but these little f ers are brutal!!
Already snapped 2 of the neighbours bits lol
Borrowed his angle grinder to flatten off the pins as well...gave him it back 30 seconds later after realising I was out of my element and it was a bit overkill for the job at hand....that and nearly setting fire to the garage from the sparks...think I'll call it quits for the day as I'm seriously into muppet territory  :LolLolLolLol:
« Reply #6 on: June 12, 2009, 10:43 PM »
Quality - LMFAO  :LolLolLolLol:
Offline Steve P
« Reply #7 on: June 13, 2009, 11:42 AM »
As mentioned, a drill is the only way to remove your knackered pins ... it takes time but the extra work is well worth it  :daumenhoch:
I'm restoring two sets at the moment ... here's the first  :coolsmiley:
Steve
« Reply #8 on: June 13, 2009, 12:29 PM »
Love your resto jobs Steve - they always look so proffesional  :coolsmiley:
Offline Steve P
« Reply #9 on: June 13, 2009, 01:02 PM »
Thanks John ... I enjoy restoring parts for my bikes  ;)  it's more like therapy to me these days too  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #10 on: June 13, 2009, 01:40 PM »
+1 on the pedals excelent job ,   :4_17_5:
bigsman
« Reply #11 on: June 13, 2009, 07:09 PM »
That is a great job there bud...you doing them using power tools or by hand?  I'm doing it all with elbow grease and getting the angles right is proving a toughie.  Also worried that drilling out the pins is going to leave me with figure 8s rather than single holes but time will tell!
