976303
crissy_criss
July 07, 2026, 10:43 AM
odysey brakes
Topic: odysey brakes (Read 1445 times)
endo
odysey brakes
June 18, 2009, 08:28 PM »
hi guys
got an odyessy evo 2 brake but can't work out how to set it up any one got any tips for me
cheers endo
subversion
Re: odysey brakes
June 18, 2009, 09:00 PM »
Put the arms on the lugs without the springs on & get your pads dialed first. Remove the arms & put your springs on & install the arms again. Note that spring orientation should make the arm resist when you twist the the brake pad towards the rim (it should flick open when you let the arm go). You achieve this by using a spanner to tension the spring & then tighten down the brake bolt into the frames lug. Install your chosen cables & then use the same method to 'centre' the brake pull on both sides (don't make the springs too tight or they will fail)
good luck mate
endo
Re: odysey brakes
June 18, 2009, 10:33 PM »
cheers mate will give it a try and let you know how i get on
endo
Re: odysey brakes
June 21, 2009, 06:15 PM »
sorted thanks for the advice buddy
tobybrown35
Re: odysey brakes
June 21, 2009, 09:04 PM »
just saved me from startin a new topic does same apply 2 oddysey a brake
subversion
Re: odysey brakes
June 21, 2009, 11:23 PM »
Quote from: endo on June 21, 2009, 06:15 PM
welcome dude
odysey brakes
