976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 11:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  re-threading forks
Author Topic: re-threading forks  (Read 2271 times)
Glen
re-threading forks
« on: June 20, 2009, 04:59 PM »
How hard is this to do? I dont have any dyes.  Anyone else done it?
lodge
Re: re-threading forks
« Reply #1 on: June 20, 2009, 05:15 PM »
Running a die over threads or cutting new threads is easy, the trouble with those forks is the threads are missing so a die of the same diameter of the original threads wont do anything, hope that makes sense.
Offline sawzall
« Reply #2 on: June 20, 2009, 05:19 PM »
if there for a show pony glen just cut the steer tube off and weld another one on,i have done it before and it works fine ;)
« Reply #3 on: June 20, 2009, 05:21 PM »
Agree with Phil, I have done this also, it is a lot less hassle than adding material and re-tapping.
lodge
« Reply #4 on: June 20, 2009, 05:34 PM »
If you know someone with a die it would be worth running a die over to repair any remaining damaged threads, and you may find you can use a few headset washers to ensure the locknut is on sound threads. would be worth a try before replacing the steerer but obviously depends on what the bikes for.
Offline stuntmaster
« Reply #5 on: June 20, 2009, 09:10 PM »
or just rewelded ie refill and the use a die  afterwards as if cleaned up would weld fine
no1stuntmaster on instagram
Offline sawzall
« Reply #6 on: June 20, 2009, 10:08 PM »
Yea its for a show bike
i would put a new steer tube on as it's a show pony ;)
