976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 11:44 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spoking Alloy Rim. Is this right????
Author Topic: Spoking Alloy Rim. Is this right????  (Read 1810 times)
Offline Redline
« on: June 21, 2009, 07:55 PM »
Hey guys,
I've only ever laced a Z rim before attempting this ukai rim, but I'm not sure if if done it right.
I think I've done what is called a 4-cross lacing system.. I think???
The issue I have is if you look at where the spokes meet the nipples it appears that the spoke is going in a different direction to the nipple and looks kinda strained if ya know what I mean.
I didn't have this issue with the Z rims as they don't have the dome shaped holes on the rim surface.
Have I done this wrong or somethin?
Have a look and let me know as I don't wanna do the other wheel until I'm sure I've done it right.
Cheers dudes  :daumenhoch:
John
bmx xxx
Re: Spoking Alloy Rim. Is this right????
« Reply #1 on: June 21, 2009, 08:02 PM »
anit got a clue, but spin the wheel and if it spins true its done.
youve done better than me,
gary
« Reply #2 on: June 21, 2009, 08:03 PM »
Looks fine John, you have done a 4x pattern there and this always pulls the nipples in the rim slightly I find.
bof
« Reply #3 on: June 21, 2009, 08:25 PM »
It looks wrong to me , show me a picture of the valve hole area and it should give me a better idea.  :daumenhoch:
Offline Redline
« Reply #4 on: June 21, 2009, 08:37 PM »
Here's the valve area dude  :daumenhoch:
bof
« Reply #5 on: June 21, 2009, 09:13 PM »
Yep, sorry but I reckon it has been built wrong, its nearly  there though.  ;)
Offline phantom photon
« Reply #6 on: June 21, 2009, 11:51 PM »
Yes, you have done it wrong. The spokes are coming in from the wrong sides ;)
You will need to undo them all and start again I'm afraid
« Reply #7 on: June 22, 2009, 12:37 AM »
Sorry to say mate but it's defo wrong  :(
The spokes next to the valve hole should lean away from it , ;) yours are leaning in.
Place the rim flat with the valve hole at 12 o'clock. One of the holes either side of the valve hole should be offset towards the top of the rim, i always make sure this is on the LHS, this may involve turning the rim over. This is the hole you should start lacing from :daumenhoch:
Tell you what , I will send you a couple of links 2moz  :daumenhoch:
« Reply #8 on: June 22, 2009, 10:36 AM »
Here's a couple of links i used when building my first wheels  :daumenhoch:
http://www.sheldonbrown.com/wheelbuild.html
http://www.jimlangley.net/wrench/wheelbuildfull.html
Might be of help to yourself or other RADsters contemplating there first wheelbuild ;)
Be patient and you shall be rewarded  :daumenhoch: ( I sound like one of them :idiot2: outside footy grounds with a placard praising the lord )  :LolLolLolLol:
Offline Redline
« Reply #9 on: June 22, 2009, 11:48 PM »
You've all been a great help as always fellas.... laced them up correctly now!
Truing them for side wobble seems easy but it's the up and downing which is pissin me off  :-\
J
