Anodising - help
brass monkey!:
--- Quote from: glynnyboy on June 26, 2009, 03:38 PM ---Who did you use, out of interest?
--- End quote ---
local firm in Essex
brass monkey!:
--- Quote from: Waxintaxin on June 26, 2009, 03:43 PM ---Light mineral oil will finnish them
--- End quote ---
cheers Rich
customparts:
The rims aren't sealed (a term used in anodising. After anodising them you dye them in which ever colour and to keep the colour in you have to seal them, most commonly in boiling water) just bad finishing! Try ptfe spray that will seal them for a while but wether you stop using the brakes is another thing. The other option is I will put them right for you!
Are the wheels like a matt finish?
If you need any help give me a shout
Paul
brass monkey!:
--- Quote from: customparts on June 26, 2009, 04:44 PM ---The rims aren't sealed (a term used in anodising. After anodising them you dye them in which ever colour and to keep the colour in you have to seal them, most commonly in boiling water) just bad finishing! Try ptfe spray that will seal them for a while but wether you stop using the brakes is another thing. The other option is I will put them right for you!
Paul
--- End quote ---
Hi Paul,
Yes the rims are like a 'matt' finish - can I do something myself or should I take them back to the anodisers?
thanks
Matt
customparts:
--- Quote from: monkeybiscuits! on June 26, 2009, 05:11 PM ---
Paul
--- End quote ---
Hi Paul,
thanks
Matt
--- End quote ---
Hello matt
There is not much you can do except for sending them back to the anodisers and asking for the rims to be chemically brightened or having them polished and then chemically brightened. What did you pay to get them done if you dont mind me asking?
Like i said if ya need any help give me a shout.
Paul
Navigation
[0] Message Index
[*] Previous page
Go to full version
