976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 09:14 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  suntour freewheel abit stiff
Author Topic: suntour freewheel abit stiff  (Read 1418 times)
LOS1969
« on: July 06, 2009, 06:28 PM »
is it fooked or what?
Offline fugazi
Re: suntour freewheel abit stiff
« Reply #1 on: July 06, 2009, 06:36 PM »
Take it off the hub & spray wd40 or similar through it, or soak it in petrol, see what it spins like then. If it's ok spray in some fresh lube, wipe off the excess & you're sorted  :daumenhoch:
JD_76
« Reply #2 on: July 07, 2009, 01:47 PM »
I had a new one like that, it had surface rust in the bearings and sounded all grindy. I just sprayed it with GT85 and ran it, sounds sweet as a nut now.
J.
thecrooch
« Reply #3 on: July 07, 2009, 02:55 PM »
you flush whatever grease was in there out like that...  its a short term fix but basically yeah its on the way out....
Offline ruff n tuff
« Reply #4 on: July 07, 2009, 02:59 PM »
depends if you fancy opening it up and re-greasing it - a real faff job and be careful not to lose the ball bearings....
HEYWOOD BMX
« Reply #5 on: July 08, 2009, 12:28 PM »
 :) Best thing is to flush out all the crap/grease with GT85 or WD40.Heat up some grease in an old pan until it starts to liquify,then drop the freewheel in/pour over it-voila 1 clean/regreased freewheel...
