Ok need help with putting mushroom grips on new bars?
<< < (4/4)
southern andy:
I always spray deodorant on to the bars and inside the grip, job done in 5 seconds.
It's the Lynx affect you see.
moley:
--- Quote from: Gary72 on July 16, 2009, 10:10 PM ---My latest method is CABLE TIES, slide about 4 or 5 cable ties into the grip, slide the grip onto the bars then pull the ties out 1 at a time :daumenhoch:
--- End quote ---
Yep!!  Easy peasy.    I use fat cable ties rather than skinny ones!!  :daumenhoch:
markyp:
didnt realise there were so many differant methods!!!!i just chuck em in a sink of hot water so they go soft then they slide on,or is this too simple or retarded??
piranha:
Its preference I've got brand new chrome on my bars and knew petrol was not a good idea, the cable ties could scratch something, the washing up liquid was good, but I know there is salt in it plus the water mix could corrode the inner part of the bar ends. The hair spray was spot on as its quite wet to start then its glue, but getting them off is another issue I'm guessing? :-\
gadd:
little bit off washing up liquid and water , on there go  :daumenhoch: , dip in boiling water for a little bit ( watch ya dont burn ya fingers when grab them) and off they come
Navigation
[0] Message Index
[*] Previous page
Go to full version
