976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 08, 2026, 01:41 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headtube & headsets diameter sizes
Author Topic: headtube & headsets diameter sizes  (Read 2241 times)
Offline 20to26
« on: July 17, 2009, 02:09 PM »
I've noticed on some of my GT frames that some headset cups fit very loosely (like they're 1.1/8"...) and I need reducers to fit a 1" headset. Strangely I just removed a Hatta MX-II from one to fit an Epoch headset and I need reducers... :-\
anybody know what gives? Are there 1" headsets with different cup size diameters on the OS bikes?
thecrooch
Re: headtube & headsets diameter sizes
« Reply #1 on: July 17, 2009, 03:23 PM »
it may be (and dont quote me on this) a road 1" headset - BMX headsets have a different size to road even though both are 1"
Chris King do an explanation that ill try and dig out in a mo....
here: http://www.aspirevelotech.com/Reference/CupSkirt.htm
« Last Edit: July 17, 2009, 03:26 PM by Crooch »
Offline 20to26
« Reply #2 on: July 17, 2009, 04:13 PM »
thanks for that Si, it seems odd that in this particular case I'm fitting a GT Epoch style headset into a GT BMX frame and it's not a snug fit. About 1mm out each side as the chart in the link shows. So perhaps GT made some narrower cup diameter headsets too for some reason.
thecrooch
« Reply #3 on: July 17, 2009, 04:16 PM »
Shim it with a coke can  - always works!
tobybrown35
« Reply #4 on: July 17, 2009, 07:05 PM »
had same problem dans comp do a shim 7 dollars and about 40 dollars postage  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #5 on: July 17, 2009, 07:13 PM »
brass sheet to make a shim,from hardware shop , comes in different guages so you can get it  a snug fit, couple o quid at the most for the amount you need, failing that
+1 on that   :daumenhoch:
Offline Gary72
« Reply #6 on: July 17, 2009, 11:40 PM »
I have a odyssey pro headset, and it needs a shim for BMX. Only ended up using the locking nut as that fits the threaded part fine.  I think Crooch dug out the chris king thing when I asked this question.
Offline Gary72
