976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 09, 2026, 08:23 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Flippin' ACS Rotor....
Author Topic: Flippin' ACS Rotor....  (Read 1861 times)
g_lamb
« on: July 19, 2009, 10:32 PM »
Anyone got any experience of setting up an ACS rotor?
Mine's doing my head in.... :tickedoff:
When I use both hands to slide the rotor up and down the stem shaft the brake caliper and lever work/move. As soon as I try to use the brake with the lever, nada....
It's as if the rotor doesn't want to slide parallel with the stem shaft
I've tried adjusting the upper and lower cables which doesn't make a difference. Same result every time
The pics below show how I've set it up. Don't know if Ive got too much spare stem and whether i need to lower it. I didn't find the destructions that helpful. They certainly weren't idiot proof...  :D
What do we reckon chaps?
I've tried a Gyro 2 BTW and it don't fit coz it's a Torker. 5" steerer tube therefore less fork thread available to fit the upper parts of the headest and the gyro plates, just b4 ne1 suggests it...  ;)
« Last Edit: July 20, 2009, 01:21 PM by Lamby »
Offline wildon
Re: Flipin' ACS Rotor....
« Reply #1 on: July 19, 2009, 10:56 PM »
you tried greasing the stem shaft?
Offline thebigdog
« Reply #2 on: July 20, 2009, 11:22 AM »
Move the top cable mount from where it is to round the side above the bottom one and see if that is ever better
Offline gary4130
« Reply #3 on: July 20, 2009, 12:08 PM »
yeah the top +lower cables need to be in line to get a better pull on the brake -the only problem is if you turn your bars +try braking also  >:( .mine i had fitted didn't work very well when bars were turned 180  :P
Offline Redline
« Reply #4 on: July 20, 2009, 01:19 PM »
Yeh.. line em up fella... mine works fine when lined up  :daumenhoch:
g_lamb
Re: Flippin' ACS Rotor....
« Reply #5 on: July 20, 2009, 01:33 PM »
Most kind. Will have a play 2nite and I'll let you know whether I took the adjustment tool to it or not  :D
Cheers fella's :daumenhoch:
adeshere
« Reply #6 on: July 20, 2009, 10:09 PM »
I guess thats why the gyro's were better as they pulled evenly from both sides
Offline gary4130
« Reply #7 on: July 21, 2009, 10:41 PM »
too true mate ,spent too much time messing about with both a spinmaster 1 +acs rotor trying with little success to get the damm things to work ok  :tickedoff: >:( :'(
Offline Wadz
  • Ride Ride Ride!!
« Reply #8 on: July 22, 2009, 08:44 PM »
i had a gyro on my rider and couldnt get any good brake pressure , turned to acs rotor and acs boa front and rear calipers
now there sh!t hot ,mine dialed in straight away ,make sure you outer cables arent over  long and you  oil the stem shaft,
my cables mounting  arent aligned, my top one is like yours straight off the back of the stem and the lower is set so the cable run down
the side of the top (as close as poss with out touching)
