976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 09, 2026, 10:11 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck Nut!!!
Author Topic: Stuck Nut!!!  (Read 2542 times)
southend_styler
Stuck Nut!!!
« on: July 25, 2009, 09:06 AM »
Excuse the title!!  :LolLolLolLol:
Right i went about fitting the crank (Sugino GT, if it helps) on my TNT yesterday and fitted it all very loosely just to make sure all was present and accounted for.
And when i went to adjust the nut which holds the bearings in on the drive side it loosened just by turning with my hand and then completely locked up.
And it just won't budge, i've tried everything, me and two mates sat for about an hour yesterday and just can't shift it, either loosening or tightening. I don't think it could have threaded it self stuck because, as i said, it turned by hand first.
What could be the problem? A bit of grit stuck in the thread?  ???
Oh, and just to make things worse, i can't take the axle out, due to the fact the non-drive crank arm is stuck on the axle!!!  :tickedoff:
Any ideas how to solve that one while we're at it?  :buck2:
Btw, i've tried everything i can think of with the crank arm before i started fitting it all together. Soaked in WD40 for a week, pure brute force, trying to wiggle it out with a vice..... I could go on all day.
Re: Stuck Nut!!!
« Reply #1 on: July 25, 2009, 09:09 AM »
Soak in Diesel for a week, should release it  ;)
southend_styler
Re: Stuck Nut!!!
« Reply #2 on: July 25, 2009, 09:13 AM »
Will this work for both the nut and the crank arm?  ???
bmxbert
Re: Stuck Nut!!!
« Reply #3 on: July 25, 2009, 09:20 AM »
 :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny:
im laughing so much it hurts.
Re: Stuck Nut!!!
« Reply #4 on: July 25, 2009, 09:21 AM »
Should do, try it. Worked for me on stuck in seat posts that were rusted in!
southend_styler
Re: Stuck Nut!!!
« Reply #5 on: July 25, 2009, 09:25 AM »
You can shut up!!!  :knuppel2:
southend_styler
Re: Stuck Nut!!!
« Reply #6 on: July 25, 2009, 09:27 AM »
Cheers Swiv mate, will give it a go!  :daumenhoch:
Could be difficult though as it's all still attached to the bike!!  >:(
bmxbert
Re: Stuck Nut!!!
« Reply #7 on: July 25, 2009, 09:27 AM »
well if your gona have a bucket of diesel laying around mate make sure its not in my shop. :knuppel2:
and there is no way in a million years that crank got that stuck by you using your hand on it..........
i tink you hit a tight spot and thought to yourself "fook it i'll just push harder"  ???
southend_styler
Re: Stuck Nut!!!
« Reply #8 on: July 25, 2009, 09:30 AM »
Get bent!!! I told you exactly what happened, and that's what happened!!!
I know it doesn't make any sense but that IS what happened!  :uglystupid2:
HEYWOOD BMX
Re: Stuck Nut!!!
« Reply #9 on: July 25, 2009, 10:10 AM »
Offline oldtired
  • Dirty Old Man
Re: Stuck Nut!!!
« Reply #10 on: July 25, 2009, 10:56 AM »
Cryptochidism     :LolLolLolLol:   nice one Haywood
southend_styler
Offline phantom photon
Re: Stuck Nut!!!
« Reply #12 on: July 25, 2009, 11:46 PM »
Have you fitted the flat washer with the nobbly bit on it and forgotton to take it off  ???
southend_styler
Re: Stuck Nut!!!
« Reply #13 on: July 26, 2009, 11:23 AM »
Dunno, think i'm gonna grab some pics of it and then everyone can see whats going on.  :buck2:
Re: Stuck Nut!!!
« Reply #14 on: July 27, 2009, 09:44 AM »
thats a good idea.
