help needed please! crank related!
<< < (2/2)
tickz:
having a look round, i think the bit I need is called the "tophat", does this sound right, I skipped class the day they taught cranks!
If this is what its called im gonna ask in the wanted section!
thanks for the help here people :)
fugazi:
Top hat is the chainring adaptor, you need the crank spindle spacers  :daumenhoch:
MartyC:
What you are missing are the bits to the right of the picture below...
Try the RadBMX shop to see if Stodgy has any in stock  :daumenhoch:
The top hat washer is the middle one and used on the drive side of the arms to secure 20mm chainwheels or spiders, you need the one below it and/or the ones to the right  ;).
tickz:
--- Quote from: MartyC on August 16, 2009, 05:30 PM ---What you are missing are the bits to the right of the picture below...
--- End quote ---
Thanks marty,
If the top hat is in the middle of the middle row then I think I need the thing to the left and the thing to the right! I would describe them as "bearing covers"  :)
HARODAVE:
yeah , the curved bearing cover and maybe a spacer or two  should finish it off nicely  :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
