To cut bars, or not?
steve Beech TA:
Cutting the bars are defo a no, keep as is and get used to them, as the donnor says get longer grips :daumenhoch:
neiljonarcus:
if you cut bars they are wrecked .. its just like polishing a tuff-neck stem
:police:
graeme:
I get you point.
They are bloody wide though!
Ive fitted them at the standard width so ill see how i get on with them.
Thanks.
pickle:
Got some fusion ones on mine and they are damn wide! :shocked:
graeme:
Not sure if mine are fusion or Kneesaver II
I found some comparison dimensions etc but not very concise.
Mine are 28" wide, not much sweep, and the uprights are wider at the bottom and taper as they come up to the crossbar.
Navigation
[0] Message Index
[*] Previous page
Go to full version
