976305
AntYeo1
July 11, 2026, 01:54 AM
smallest sprocket with USA BB
Topic: smallest sprocket with USA BB (Read 3145 times)
graeme
Curb Endo
August 26, 2009, 08:04 PM »
Sprockets smaller than 40t are a mystery to me LOL
I am thinking of fitting a 9t freecoaster hub so would need something like a 23t sprocket.
Will this work with a USA BB and a 1 piece crank?
When do you start to get into 'micro' teritory? (i dont even know what that means really!)
Thanks.
harris
Founding Fathers
Hoffman's Love Child
Re: smallest sprocket with USA BB
August 26, 2009, 08:16 PM »
its all about the rear geometry some bikes will let you fit microdrive but some will make the chain rub on the underside of the chainstay
some will some wont...i did run a 10t rear and 28t on my trickstar
graeme
Curb Endo
August 26, 2009, 08:19 PM »
cr*p, hadnt thought about that.
Ive got chainstay brakes too (88 haro master)
Can anyone tell me the diameter of 9t drivers and 23t sprockets? Then i can try and work out if it will fit.
Or, diameters of drivers/sprockets near these sizes to give me some idea.
I guess im going to need the diameter without the teeth so i can work out where the inside of the chain will be.
HEYWOOD BMX
August 26, 2009, 08:28 PM »
Most modern day sprockets are made to fit on 3 pc cranks,either 22 or 19mm borehole.Chainwheels for 1 pc cranks usually need 23.8mm borehole sprockets so take care before buying anything.
Last Edit: August 26, 2009, 08:32 PM by HEYWOOD BMX
graeme
Curb Endo
August 26, 2009, 08:29 PM »
Quote from: HEYWOOD BMX on August 26, 2009, 08:28 PM
m
Is that code for 'you havent got a chance'?
LOL
lazychubs
Founding Fathers
BMX Nerd
August 26, 2009, 08:32 PM »
i dont think it will work on a 88 master i think 36/13 would struggle
harris
Founding Fathers
August 26, 2009, 08:35 PM »
bb height will be the yes or know
graeme
Curb Endo
I know its unlikely, but i'd like to know for sure.
If not, can i fit a bigger driver to a KHE geisha light freecoaster hub?
graeme
Curb Endo
August 26, 2009, 09:37 PM »
Been looking at my bike, and pics online, i MAY just get away with it, the curved chainstays look likt they will help.
Ill look into bigger drivers for it though. I know nothing about this kind of hub so i dont know if you can fit different size drivers or not.
I found one 10t driver for it, but are the drivers hub specific?
harris
Founding Fathers
August 26, 2009, 09:39 PM »
im not sure how big the geisha goes ,mines a 9t
HEYWOOD BMX
August 26, 2009, 09:41 PM »
Some drivers are model specific.Drop an e-mail to KHE or Ison Distribution,they might be able to help.
graeme
Curb Endo
Reply #11 on:
August 26, 2009, 09:46 PM »
I was wrong, its an 11t i can get for the geisha. An extra $50 though!
Apparantly they used to come with 11t, but now 9t.
I guess its going to be pretty hard to work out if it will all fit/work or not without buying the stuff and trying it
harris
Founding Fathers
Reply #12 on:
August 26, 2009, 09:49 PM »
what frame are you using ,i have all the freecoasters just about available in most sizes and chainrings with a tonne of frames
i could see what fits what....im of to the states in 2 days thou
graeme
Curb Endo
Reply #13 on:
August 26, 2009, 10:19 PM »
Its an 88 haro master, run with the rear as short as possible.
I just fancied a freecoaster and the 9t geisha is available cheap
Thanks.
Oh, i assume the 88 has the same rear end as all the other masters with the chainstay stands.
bof
Reply #14 on:
August 26, 2009, 10:35 PM »
I have a 28 tooth profille sprocket somewhere with a damaged tooth that you can have ( yes free ) but i wont be able to get it in the post till next week . LMK if thats any use too you . It might help you measure up and see if it will fit.
graeme
Curb Endo
Reply #15 on:
August 26, 2009, 10:36 PM »
that would be great, thanks. PM on its way.
