976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 11, 2026, 06:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  haro Axle spacers
Author Topic: haro Axle spacers  (Read 1682 times)
spleen1970
haro Axle spacers
« on: August 29, 2009, 08:49 PM »
93 haro master forks the ones with fork stander screw thread at the bottom
now then I have gone to fit a skyway Front wheel with a 10mm axle but it dose'nt fit the drop out is to big .I have been advise I need a top hat spacer to fit the wheel .
Is this correct ?
Dose anyone have any ?
Please let me know
many thanks sean
Re: haro Axle spacers
« Reply #1 on: August 29, 2009, 09:01 PM »
check out the rad shop they have some there  :daumenhoch:
spleen1970
« Reply #2 on: August 29, 2009, 09:14 PM »
Cheers dude il have a look :daumenhoch:
spleen1970
« Reply #3 on: August 29, 2009, 09:27 PM »
Iv been told it's not 10mm to 14mm adaptor's I require they said I need a top hat spacer & that the forks are 12mm drop outs not sure if this is correct the rear wheel drop out's are 10mm the forks are tapered
Cheers sean
Offline graeme
« Reply #4 on: August 29, 2009, 09:53 PM »
vert ego has em, you need the SE axle washers, they are 10mm to 12mm top hat washers.
I recently got some for my haro forks.
HEYWOOD BMX
« Reply #5 on: August 29, 2009, 09:56 PM »
http://www.chainreactioncycles.com/Categories.aspx?CategoryID=179
 Atomlab 12-10 conversion
 Lots of forks have the same problem.The washers look like these,but I got 4 from my local bike shop for a quid.
Offline HARODAVE
« Reply #6 on: August 29, 2009, 09:58 PM »
alans sell 10-14mm axle converters too ..i got  some for my 06 sport and they`re bob on!!
