976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 10, 2026, 05:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  primo power bite removal
Author Topic: primo power bite removal  (Read 1530 times)
Glen
« on: September 04, 2009, 05:06 PM »
Do Just hammer like fook on the axle to get it out of the BB?
fouronethreeoh!
Re: primo power bite removal
« Reply #1 on: September 04, 2009, 05:32 PM »
Assuming the arms are off, squirt loads of wd40 in between spindle/bearings, then twat away!
Probably rusted in a bit.
motomagII
« Reply #2 on: September 04, 2009, 05:45 PM »
put the crank bolt back in then hit it with hammer so as not to damage the axle .they are quite tight but once moving it gets easier
« Reply #3 on: September 04, 2009, 05:48 PM »
Poor boiling water over the crank end, alloy expands quicker than steel so you should be able to get some "give" on them  :daumenhoch:
« Reply #4 on: September 04, 2009, 05:58 PM »
Be sure to use a woodne/rubber/plastic mallet as these need alot and i mean of hitting to get off! even with WD40 :daumenhoch:
« Reply #5 on: September 04, 2009, 06:02 PM »
Get some diesel in there too, not WD40  ;)
« Reply #6 on: September 04, 2009, 06:38 PM »
the BB is tigher than a nuns cnut though.  Its the original
