976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 13, 2026, 11:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Home made "Slammers"
Author Topic: Home made "Slammers"  (Read 5345 times)
« on: September 17, 2009, 12:15 PM »
Slammer
I have been having a bit of trouble with my wheel slipping forward (usually from heavy Icepicks) so for a while now I’ve been wanting do to something to sort it out. I got some new wheels recently so it seemed like a good time.
Have done stuff in the past with rear facing chain adjusters but although they worked great, they didn’t look that good and I didn’t really want  to be welding stuff onto my frame. I also wanted something that worked with and without pegs, cos I like to take mine on and off.
(This is a mod I did to a challenger frame a good few years ago)
I like *SIMPLEBMX Slammer idea (even though there is no “adjustment”, and nothing you can do when the chain stretches) so I thought Id have a go at making some.
*(http://www.simplebmx.com/products.html#slammer/slammers)
First up, I measured what I need and sketched it up. I wanted a washer the same diameter as my pegs, with a “lump” to fill the gap in front of the axle. I made the lump longer than I needed so I could file it to fit later. I continued the Lump behind the axle as well. This was to help hold the slammer in line but also to stop the dropout closing up if it got hit when grinding. Finally, my pegs have anti spin pins so I wanted the washer to accommodate these.
Then I made a solid model of the sketch. I used ProEngineer which is pretty horrid but its what we use at my work.
From this I did a 2D drawing of the part and gave it to the workshop at my work to make.
2 machined parts
Then the hard bit, getting them to fit! I had to take quite a few mm’s off the front of the lump, and also make it nice and round to fit the curve at the front of the dropout. It took the best part of an evening to get them both done, but wasn’t too bad. I made them a tight fit, which I know isn’t doing my chain any favours, but I could always file more off if the chain was too tight, and I also needed to allow for the chain to stretch
I bit of cleaning up and they were ready to be sent to anodising (another perk of my job)
That’s better. Nothing but Black on my bike, thank you!
And there they are. Finished and fitted. They are quite a tight fit in the dropouts so when I take the wheel nuts (bolts) off they stay in place. This means that I can take my pegs on and off easily without the wheel moving. If I ever need to get the wheel out, I just pop the washers out and the wheel can move forward enough to drop the chain off.
I’m pretty happy with out they came out. Now I’ve got a whole weekend of riding ahead of me to see if they actually work!!
« Last Edit: September 17, 2009, 04:00 PM by S&MAlex »
J Rolla
Re: Home made "Slammers"
« Reply #1 on: September 17, 2009, 12:23 PM »
Nice work  :coolsmiley:
JT71
« Reply #2 on: September 17, 2009, 12:25 PM »
good work Mr Leech, they look great in the flesh too...and weightless, are they made out of helium infused ali?
so, think we had this convo already, your chain is your old one, so it is pre-stretched right?
« Reply #3 on: September 17, 2009, 12:30 PM »
No, the chain is brand new  :-\
But hey, how much is my chain really gunna stretch? Its only short and its not like I do many "miles" on it. The cranks rotate backwards more than they do forwards!
firebird
« Reply #4 on: September 17, 2009, 12:40 PM »
 :4_17_5:
Offline billstup
« Reply #5 on: September 17, 2009, 03:18 PM »
You are a clever fcuker Alex, now get a patent on them and make some money before someone else does  :daumenhoch:
moley
« Reply #6 on: September 17, 2009, 03:21 PM »
Nice one!!  :daumenhoch:
And you could always have different sizes for different dropout wheel positions!!   :)
Offline billstup
« Reply #7 on: September 17, 2009, 03:24 PM »
I was just thinking that Moley, you could offer a set of 3 or 4 slammers all with a mm of difference between them, job done and we`re all millionaires  :daumenhoch:
moley
« Reply #8 on: September 17, 2009, 03:32 PM »
I'd buy a set!! :daumenhoch:
« Reply #9 on: September 17, 2009, 03:46 PM »
What, like these?
http://www.winstanleysbmx.com/product/16018/Simple_Wheel_Slammer
http://bmx.transworld.net/videos/how-to-install-a-simple-wheel-slammer/
They are my version of Simple Bikes, wheel slammers. But mine cost me less .... and are better! lol
(I have added the SimpleBMX link to the Original post)
« Last Edit: September 17, 2009, 04:04 PM by S&MAlex »
Dr.Robotnik
« Reply #10 on: September 26, 2009, 06:10 PM »
Nice, I run a similar set I made on my current bike, although mine also help accommodate my 10mm rear axle in the 14mm dropouts. Yours are much nicer though seeing as they are anodized, mine are raw and consequently a bit haggard from oxidisation now.
« Reply #11 on: September 26, 2009, 06:24 PM »
nice work alex,simple,clean bloody good work  ..dan
