976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 10:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  AD990 type brake help please
Author Topic: AD990 type brake help please  (Read 1641 times)
« on: September 26, 2009, 09:13 AM »
I'm running a AD999 brake on my chainstays with a 36t chainwheel. The 'cable end' of the brake arm is very close to the teeth of the chain wheel.
I could use a smaller chain wheel and change my rear drive, but I would feel better changing the brake.
I have noticed the Odyssey EVO II looks to have short arms, but I have not seen this brake insitu, could some one please confirm this is the case or does any one know of a brake that has shorter arms?
Thanks
Bren
Re: AD990 type brake help please
« Reply #1 on: September 26, 2009, 09:19 AM »
most of mine are close,i re adjust mine by using more spacers or removing them on the brake blocks
they then sit the arms away from the chainring.i find this happens alot .
but i will go measure some evos..one mo
« Reply #2 on: September 26, 2009, 09:20 AM »
Cheers :daumenhoch:
« Reply #3 on: September 26, 2009, 09:23 AM »
yes the new evos are shorter around 6mm or more ,ive got round this a few times.
im sure it was by removing some spacers on the blocks so the arms sit higher.
« Reply #4 on: September 26, 2009, 09:37 AM »
Nice one, Dan. I've already swapped over the spacers and it's still very close; rideable, but a bit dodgy ;)
Have you taken all the spacers out between the brake arm and the brake block?
« Reply #5 on: September 26, 2009, 09:41 AM »
i think i left 2 , but ye they do run close on the mid size gearing.mine have never hit thou just look close.
when this happens i put the clock narp on the other side ,non drive side.
« Reply #6 on: September 26, 2009, 11:36 AM »
Cheers mate :daumenhoch:
kirk
« Reply #7 on: September 27, 2009, 02:26 AM »
File the teeth down on the chainwheel Bren  ;)
« Reply #8 on: September 27, 2009, 08:32 AM »
buy a proper bike :LolLolLolLol:
on a serious note, dont worry about it, as if it is too close the chain will let you know as it will jump off the chain wheel  :daumenhoch: (no change there then) :2funny:
« Last Edit: September 27, 2009, 08:35 AM by OrgasmDonor »
