976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 09:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  crank is drivin me nuts
Author Topic: crank is drivin me nuts  (Read 2482 times)
Offline Peanut
« on: October 07, 2009, 10:20 AM »
left hand crank arm keeps coming loose, driving me mental, like riding a bike made of jelly
toys19
Re: crank is drivin me nuts
« Reply #1 on: October 07, 2009, 10:22 AM »
square taper BB axle with alloy crank arm? if so the taper in the arm is fooked - I dont think there is a repair...
bmxbob
« Reply #2 on: October 07, 2009, 11:19 AM »
used to use a coke can shim bitd  :LolLolLolLol:
« Reply #3 on: October 07, 2009, 11:23 AM »
Give us a  bit more info - there's bound to be a cure.  Make and model of crank, stick a picture up maybe?
toys19
« Reply #4 on: October 07, 2009, 11:24 AM »
yeah I used this but it never lasted long..
« Reply #5 on: October 07, 2009, 11:25 AM »
I had trouble with the non drive arm on my rider coming loose - simple addition of a washer sorted it  :daumenhoch:
Offline Peanut
« Reply #6 on: October 07, 2009, 12:20 PM »
don't know the make, it's a splined axle
« Reply #7 on: October 07, 2009, 12:22 PM »
should be fine??
have you cleaned the threads and then use fresh threadloc?   ???
washer?
Offline Peanut
« Reply #8 on: October 07, 2009, 12:27 PM »
has no threadlock which might be the problem, anyone know of a cheap homemade threadlock solution?
toys19
« Reply #9 on: October 07, 2009, 02:39 PM »
superglue
thecrooch
« Reply #10 on: October 07, 2009, 03:19 PM »
have you stripped it out at all?
mine used to come loose because the sleeve over the spindle (inside the BB) was too long.
probably best to get your LBS to look at it...
« Reply #11 on: October 07, 2009, 03:23 PM »
Plumbers PTFE tape  :daumenhoch:
Offline Peanut
« Reply #12 on: October 07, 2009, 04:27 PM »
i shall fiddle tonight, thanx chaps
trasher
« Reply #13 on: October 07, 2009, 06:10 PM »
Enough if your personal life
Back on the subject .get down to halfirds and get some
Locktite threadlock
