976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 09:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Internal spacer for Redline 401's - length?
Author Topic: Internal spacer for Redline 401's - length?  (Read 1607 times)
funkwit
« on: October 07, 2009, 09:09 PM »
Hi all, can you advise?
I'm installing some 401's (American BB with sealed bearings), but when I received the crankset, it didn't have an internal spacer included. I'm trying to track one down, but what length should it be? And would a Profile gold spacer do the job? I see you can buy them on various websites but none of them actually tell you the length and I don't want to buy the wrong one.
Any advice appreciated - thanks fellas.
Marc
Re: Internal spacer for Redline 401's - length?
« Reply #1 on: October 07, 2009, 09:12 PM »
Different sizes to suit different BB shells mate.
I believe there's an imperial and metric variance.  Measure your BB width overall and then post that up, someone will have your answer for you  :)
funkwit
« Reply #2 on: October 07, 2009, 10:59 PM »
Cheers mate. The exact width of the BB is 6.7cm (1983 GT Pro)....
Offline kuwahero
    • Western Titans
« Reply #3 on: October 07, 2009, 11:11 PM »
you will need one approx 58mm long. I have one here that is 59mm which you could file a mm off.
pm me if you want it
« Reply #4 on: October 07, 2009, 11:38 PM »
Bosh!!!  Sorted   :daumenhoch:
You can actually use a slightly longer spacer with no problems. What happens is one bearing cup sits ever so slightly proud of the BB shell, which in itself isn't a problem. At least that way you're guaranteed not to be putting any incorrect load on the bearings when you tighten everything up.
funkwit
« Reply #5 on: October 07, 2009, 11:46 PM »
Thanks guys, much appreciated - Kuwahero YGM.
moley
« Reply #6 on: October 07, 2009, 11:49 PM »
Profiles are the same.   Always have your Sprocket side BB flush to the Shell.  And the other side will be around 1mm off the shell.   No Crushed bearings and no play.  Everything is A OK.  Spin a treat!!  :daumenhoch:
