976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 08:58 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How bad can a rim be before you can't straight it?
Author Topic: How bad can a rim be before you can't straight it?  (Read 2429 times)
bmxboy70
« on: October 17, 2009, 08:13 PM »
Ok I bought 2 rims from eviel bay for £3.20! One is straight the other is not! What do you think will it pull back with build or do I do something else to it first?
Thanks in advance!!!!!!!!!!!!
bmxboy70
Re: How bad can a rim be before you can't straight it?
« Reply #1 on: October 17, 2009, 08:24 PM »
bmxboy70
« Reply #2 on: October 17, 2009, 08:27 PM »
Nice Hammer!
bmxboy70
« Reply #3 on: October 17, 2009, 08:29 PM »
Maybe if I land hard?( which is pretty likely!) It will improve?
Bettyswallocks
« Reply #4 on: October 17, 2009, 08:36 PM »
You need to dust that table...  :D
HEYWOOD BMX
« Reply #5 on: October 17, 2009, 08:39 PM »
 :) I had an alloy rim like that a while back was NOS,but had been bent in storage).I stuck it on the patio and stuck 3 big flat paving stones on top.When I had the wheel built up,it came out fine.
bmxboy70
« Reply #6 on: October 17, 2009, 08:42 PM »
Don't F..king Rayburn problems all day!!! Just don't go there!!!!!!!!!!! :LolLolLolLol:
bmxboy70
« Reply #7 on: October 17, 2009, 08:46 PM »
So......they will take a fair bit of weight then?
HEYWOOD BMX
« Reply #8 on: October 17, 2009, 10:13 PM »
 Yep,but be careful you don`t overdo it or the rim will die! I added 1 slab at a time and left them for a few days...
« Reply #9 on: October 18, 2009, 12:36 PM »
The best way to see if it's totally fooked is to hold the rim against your stomach with your elbows and forearms on the rim and with both hands holding the rim oppsite your stomache pull it upwards, if it's fooked it will "spring" back  :daumenhoch:
bmxboy70
« Reply #10 on: October 18, 2009, 08:57 PM »
you've lost me on that one!lol
