976306 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 11:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Setting MX901's
Author Topic: Setting MX901's  (Read 1653 times)
Cerbera
Setting MX901's
« on: October 24, 2009, 07:39 PM »
Is there a how to guide on here on how to set up MX 901's just want to make sure I'm doing it 100% right.
Re: Setting MX901's
« Reply #1 on: October 24, 2009, 07:44 PM »
just dont do the front and back bolt up too tight and play around with the lever so both side calipers move  :daumenhoch:
Cerbera
Re: Setting MX901's
« Reply #2 on: October 24, 2009, 07:46 PM »
Thanks, whats the recommended distance between brake block and rim?
Re: Setting MX901's
« Reply #3 on: October 24, 2009, 07:51 PM »
Not much mate a few mil either side will be fine  :daumenhoch:
Cerbera
Re: Setting MX901's
« Reply #4 on: October 24, 2009, 07:53 PM »
Magic, thanks.  :daumenhoch:
currio
Re: Setting MX901's
« Reply #5 on: October 25, 2009, 08:07 PM »
I am sure I remember seeing written on the packaging of some brake blocks, they said to use the card packaging as spacing while you clamp the cable nut.
I guess that would have been around 2mm.
Re: Setting MX901's
« Reply #6 on: October 26, 2009, 03:20 PM »
makes sence that shaun.be easier than trying to gauge it too
sid1972
Re: Setting MX901's
« Reply #7 on: October 26, 2009, 04:12 PM »
Do as the above (card spacers), but I also use a 'luggage fabric type ratchet strap' to lock them into postion close to the rim (put the strap around both blocks, through the rim and over the tyre)..
This then free's up both hands to tension the cable and tighten the nuts, if u know what I mean.
Was always a pain in arse before someone showed me this method.
Cerbera
Re: Setting MX901's
« Reply #8 on: October 27, 2009, 04:50 PM »
Good idea! I'll try that when I'm setting them.  :daumenhoch:
