976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 15, 2026, 04:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  drop out savers
Author Topic: drop out savers  (Read 2717 times)
Offline 58 delray
drop out savers
« on: October 30, 2009, 08:50 AM »
as a newbie on here i have been looking back through pages of stuff that i have missed through not being here from the beginning and have seen some stunning restos.
 one thing i noticed though was the use of oval type dropout savers on many looptail rippers, these are not something i remember from bitd, the savers i remember that came with LTRs were large black washers, one of which had a raised portion to fit inside the dropout.
is there any reason why these original type savers are not used?
andy
ps this is not a dig at the fine restos out there, just curious thats all
« Last Edit: October 30, 2009, 10:31 AM by 58delray »
thecrooch
Re: drop out savers
« Reply #1 on: October 30, 2009, 09:57 AM »
http://www.helixbmx.net/dropouts.htm
whether these are better or not i dont know, but you can buy direct and he ships quickly.
Offline 58 delray
Re: drop out savers
« Reply #2 on: October 30, 2009, 10:32 AM »
not after any mate, just curious thats all,
andy
Offline Redline
Re: drop out savers
« Reply #3 on: October 30, 2009, 03:54 PM »
i would imagine that people use those long saver to cover up damage already done to the dropouts. I personally do as much work as I can to get dropouts on my builds looking mint then just use nylon washers instead. Personally I don't like to look of those long dropout savers!
J
Re: drop out savers
« Reply #4 on: October 30, 2009, 04:40 PM »
as john says, to cover up damage drop outs or as in my case, protect the paint and alloy, the thick alloy can easily crush when tightened...
trasher
Re: drop out savers
« Reply #5 on: October 30, 2009, 06:44 PM »
i use them on my ripper ,,for riding ,,you cant tighten up the nylon washer enough for riding ,and because the rippers alloy then the savers save the dropouts
personally i like them on rippers  :daumenhoch:
moley
Re: drop out savers
« Reply #6 on: October 31, 2009, 09:22 PM »
I have a PK Ripper XL that I want to use for riding and I want to use Chain tensioners!!
It looks like I have to use the drop out savers on the rear to pad the axle. I have two Washers with the insert (like a top hat).
How can I use chain tensioners with them?
Ideally I'd like to get the washers on the inside of the frame to allow the chaintensioners to be used on the outside (but I dont think that will be possible)!!
Do you see what I mean?
I haven't build it yet and it is a later model OS legal Ripper but it looks similar to the piccys.
So how do I pad the axle and use chain tensioners?  ???
HEYWOOD BMX
Re: drop out savers
« Reply #7 on: October 31, 2009, 10:04 PM »
 :) Won`t the chain tensioners protect the frame,especially if you use alloy ones?
moley
Re: drop out savers
« Reply #8 on: November 02, 2009, 12:01 AM »
Yeah but isn't the axle smaller in diameter than the dropout.
I've never had a PK before but I thought thats why the dropout savers are tophats, so that they fill the gap!!
Re: drop out savers
« Reply #9 on: November 02, 2009, 08:23 AM »
think they are top hats to keep the wheel central, other wise the narrow guage axle has a lot of play, i used chain tensioners on my pibull ripper but has to be the first washer and the narrow washer that comes with the chain tensioner digs into the frame, i never tried using top hats but think with all these washer you wont have room to put the nut on, besides the top hat washers also have a very narrow washer part that damages the frame...
