976306 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 11:25 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cutting bars down?
Author Topic: Cutting bars down?  (Read 2193 times)
Offline Gary72
Cutting bars down?
« on: November 24, 2009, 08:52 PM »
Whats the best and neatest way. Was thinking of using a plumbers pipe cutter?
Anyone got any tips.
Thanks
Gary
Offline Bigfrawg
Re: Cutting bars down?
« Reply #1 on: November 24, 2009, 08:53 PM »
that will only fook the cutter up as they are only designed to cut copper. grinder or hacksaw followed by a file  :daumenhoch:
neiljonarcus
« Reply #2 on: November 24, 2009, 09:42 PM »
why why why             why cut bars down buy smaller ones ............ please tell me they arn,t old school bars  :'( :'( :'( :'(
Daletsunami
« Reply #3 on: November 24, 2009, 09:56 PM »
I agree with neil, see if anybody fancies swapping you for some smaller ones  ;)
Bettyswallocks
« Reply #4 on: November 24, 2009, 10:00 PM »
Big hacksaw... easy...   :daumenhoch:
Offline fugazi
« Reply #5 on: November 24, 2009, 10:00 PM »
Might want a cutting disc in a grinder if they're newskool heat treated bars, I tried cutting some the other week & a hacksaw wouldn't touch them  :shocked:
Offline Gary72
« Reply #6 on: November 24, 2009, 11:00 PM »
They are United Grande bars and are 29 inches wide only want to take 1/2 inch of either side. Cant swap for smaller as I've had my forks powdered to match. Think I will give the pipe cutter ago. Only problem is in the past on copper pipe I have managed to wander along the pipe :LolLolLolLol:.
So I think I'm going to try and put some locking grip collars on to stop this. If not the cutting disc at work and the grind wheel will be seeing some action. >:D
evamedia
« Reply #7 on: November 25, 2009, 10:37 AM »
Hacksaw, if you've got the right blades
and even Mr Williams cuts his own bars down
moley
« Reply #8 on: November 25, 2009, 10:41 AM »
I used a pipe cutter on a seat post.
It took ages but it did give a good cut!!  :daumenhoch:
lodge
« Reply #9 on: November 25, 2009, 11:12 AM »
I struggled with a hacksaw on my slam xlt's, pipe cutter wouldnt look at them.
Depends if been heat treated as to how hard to cut also quality of hacksaw blade makes a big difference.
Dr.Robotnik
« Reply #10 on: November 25, 2009, 03:48 PM »
Pipe cutter blades come in different types for cutting different materials of pipe. Basically they come stock ready for a soft copper pipe. If you have a heat treated (read hardened) steel bar you will have to change the cutting blade.
Best bet is to pop down to your local bike shop and ask to borrow their Park hacksaw guide. This clamps onto the bar/steerer tube and has a slot to position the blade. Nice straight, perpendicular cuts every time.
matt
« Reply #11 on: November 25, 2009, 06:06 PM »
i couldnt agree more, cutting your bars is like painting tuffs..... you just dont do it,  sorry neil i couldnt resist   :daumenhoch:
Offline Gary72
« Reply #12 on: November 25, 2009, 07:22 PM »
To answer the question WHY?
As Mick Jagger once sang  "You cant always get what you want"
If they were old school I wouldn't do it. But I wanted some bigger bars so I bought these ones knowing that if they were too high I could drop the stem or if they were too wide I could narrow them slightly :)
Gary
spleen1970
« Reply #13 on: November 25, 2009, 07:37 PM »
Dude use a disc cutter with a slitting disc on it's a very thin cutting disc easy to get hold of will cut through Yer bars like hot knife through butter  :daumenhoch:
