976306 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 08:32 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  V-BRAKE SET-UP TIPS?
Author Topic: V-BRAKE SET-UP TIPS?  (Read 2139 times)
HEYWOOD BMX
« on: November 30, 2009, 02:01 PM »
 :) I`m running a DXR setup with a linear slic cable.Whenever I pull the lever ,only the right side arm pulls to the rim.The leftside (noodle side) does nothing.Everything is lubed properly,but I still can`t get it working .... :-[
Offline Bigfrawg
Re: V-BRAKE SET-UP TIPS?
« Reply #1 on: November 30, 2009, 02:23 PM »
have you tried adjusting the springs ?
Offline Haro82
« Reply #2 on: November 30, 2009, 02:32 PM »
Bend the springs out a bit to get a bit more 'spring' and then adjust the screws to move the non moving side away from the rim.
Offline Gary72
« Reply #3 on: November 30, 2009, 07:13 PM »
Sounds like spring tension, Is one side wound all the way in. I normally feel both sides by pushing them towards the rim to make sure the tension feels equal, Do this without the cable connected..
Hope that makes sense
HEYWOOD BMX
« Reply #4 on: November 30, 2009, 08:05 PM »
 :) Cheers,I`ll try the spring bending thing.I`d tried the adjuster screws without any success.Don`t rate the DXR very highly TBH,looks like a Deore with a new name & bigger price..
Offline Gary72
« Reply #5 on: November 30, 2009, 08:10 PM »
I was always told not to bend the springs as it actually weakens them. On the mount there is normally 3 holes to help spring tension, Sure you haven't put one side in a different hole? And hence making that side very stiff?
Gary
« Reply #6 on: November 30, 2009, 08:18 PM »
try this james....
poor bike.... :'(
HEYWOOD BMX
« Reply #7 on: November 30, 2009, 08:28 PM »
 :) Mounted properly.I`ll bend the springs,if that doesn`t work the brake is going to face death by sledgehammer :daumenhoch:
« Reply #8 on: November 30, 2009, 08:29 PM »
i gave you that brake.... :-[
Offline Gary72
« Reply #9 on: November 30, 2009, 08:31 PM »
If you cant get it to work send it to me, If I cant get it to work I will turn it into a pile of shavings on the grind wheel at work and send it back to you :LolLolLolLol:
HEYWOOD BMX
« Reply #10 on: November 30, 2009, 08:36 PM »
 :) Sorry Sam,this brake doesn`t love me.I feel another A-Brake coming on :daumenhoch:
Offline Dingobmxer
« Reply #11 on: November 30, 2009, 08:55 PM »
James,
Take it off and clean the posts, lube lightly with some grease and put the brake back on with the locating pins in the MIDDLE hole of the 3 on your frame, adjust the pads then put the cable in, you can get even tension by either bending the springs OR using the adjustment screws to add more tension to the looser side or slacken off tension on the springier side
Hope this helps?
Dingo
