976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 09, 2026, 04:43 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  fixing skyway alloy hub (concaved in)
Author Topic: fixing skyway alloy hub (concaved in)  (Read 1795 times)
firebird4130
« on: February 10, 2010, 06:40 PM »
I've got a skyway front wheel, looks like the alloy hub has concaved inwards ,any tips on pushing it out?
Cheers  :daumenhoch:
Offline JAY
Re: fixing skyway alloy hub (concaved in)
« Reply #1 on: February 10, 2010, 07:06 PM »
Piece of cake, take the axle out , the bearing race also knock out of the hub aswell, take out the clear plastic insert from the middle of the hub so that you can see clearly the inside of hub you need to straighten. With the wheel ideally lying down onto something that will not damage the wheel and allow the hub to be knocked through,Use something (piece of hardwood, etc)to knock the hub back out into its correct shape, they are easy to do, just don't over do it.
Hope that makes sense.....
« Last Edit: February 10, 2010, 07:15 PM by JAY »
firebird4130
« Reply #2 on: February 10, 2010, 07:09 PM »
cool, that's a great help,gonna give it a go, cheers mate  :daumenhoch:
moanjam
« Reply #3 on: February 10, 2010, 07:53 PM »
hey fraz post a pics if you try it dude  :daumenhoch:
firebird4130
« Reply #4 on: February 10, 2010, 08:38 PM »
will do mate  :daumenhoch:
Offline Steve P
« Reply #5 on: February 10, 2010, 10:56 PM »
I used a large spacer that sat neatly on the rivet heads ... with a decent size bolt it pulled the hub out perfectly  :daumenhoch:
firebird4130
« Reply #6 on: February 14, 2010, 11:43 AM »
not had much luck with this, I tried knocking it out but it's not budging, I'm worried I'll crack the alloy if I smash it too hard ?
Offline Bigfrawg
« Reply #7 on: February 14, 2010, 11:54 AM »
this method is more effective especially if you are worried about smashing fook out of the hub  :daumenhoch:
moanjam
« Reply #8 on: February 14, 2010, 12:11 PM »
how do you get the bolt to attach to the hub ?
firebird4130
« Reply #9 on: February 14, 2010, 01:46 PM »
that does sound safer, have you got a pic/illustration
Cheers  :daumenhoch:
