976343 Posts in 138998 Topics by 6443 Members - Latest Member: BMX1970 September 02, 2026, 12:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Top hat washer
Author Topic: Top hat washer  (Read 2263 times)
Offline wildon
Top hat washer
« on: February 22, 2010, 10:30 AM »
Alans have top hat washers for £3 but there are 3 sizes.  What size do i need to fit a normal disc/spider onto flights?
• 23.8 to 22mm.
• 23.8 to 19mm.
• 22.2mm to 19mm.
« Last Edit: February 22, 2010, 10:33 AM by wildon »
moley
Re: Top hat washer
« Reply #1 on: February 22, 2010, 10:35 AM »
19mm spindle but you'd have to check your Sprocket/Spider for the other dimensions.
HEYWOOD BMX
Re: Top hat washer
« Reply #2 on: February 22, 2010, 11:00 AM »
What disc/spider will you be fitting? Old school ones will usually be 23.8 down to 19mm.Try to get the shortest washer possible as longer ones don`t sit flush against the arm spindle boss.
« Last Edit: February 22, 2010, 11:10 AM by HEYWOOD BMX »
Offline wildon
Re: Top hat washer
« Reply #3 on: February 22, 2010, 11:09 AM »
I got a Sugino power disc and a Sugino spider
HEYWOOD BMX
Re: Top hat washer
« Reply #4 on: February 22, 2010, 11:10 AM »
 23.8 to 19mm then :daumenhoch:
Offline wildon
Re: Top hat washer
« Reply #5 on: February 22, 2010, 11:24 AM »
Top man  :daumenhoch:
