975941 Posts in 138955 Topics by 6391 Members - Latest Member: Buster_3007 May 24, 2025, 03:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Do you need laquer over Plastikote spray...
Author Topic: Do you need laquer over Plastikote spray...  (Read 4503 times)
« on: March 15, 2010, 09:51 PM »
Just done a pretty good job of spraying a frame... first go for fookin years.
but do i need to laquer the frame over the spray... LMK please you rattlecan rulers  :daumenhoch:
firebird4130
Re: Do you need laquer over Plastikote spray...
« Reply #1 on: March 15, 2010, 09:55 PM »
if it's gloss you shouldn't need it  :daumenhoch:
« Reply #2 on: March 15, 2010, 10:01 PM »
Satin
firebird4130
« Reply #3 on: March 15, 2010, 10:37 PM »
it doesn't need it, but if you wanted it glossy then it might be an idea but don't use a car spray one as it will make it peel
Offline fugazi
« Reply #4 on: March 15, 2010, 11:23 PM »
You can get Satin clearcoat, or just give it a coat of low gloss wax.
« Reply #5 on: March 16, 2010, 06:45 AM »
No way! really... I nearly did exactly that... Cheers Franz!  :angel:
Would the Satin Clearcoat mentioned above make it peel? or is it ok to just leave it as the Satin Super paint and not lacquer?
firebird4130
« Reply #6 on: March 16, 2010, 08:24 AM »
 :daumenhoch: It should be fine without it, but would protect the paint more with it I guess as long as it's made by plastikote.
« Reply #7 on: March 16, 2010, 10:10 AM »
Irie  :daumenhoch: thanks Franz  :angel:
