976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 12:43 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Best Trick 4 Rust Removal ! Whats works ?
Author Topic: Best Trick 4 Rust Removal ! Whats works ?  (Read 2658 times)
« on: April 01, 2010, 08:47 PM »
Got a pair of Forks (MRD Obviously) Which have very rusty drop outs . I could flat off all the rust but may go the disolving trick way  ;) whats worked 4 u guys ?  ::)
Offline Gary72
Re: Best Trick 4 Rust Removal ! Whats works ?
« Reply #1 on: April 01, 2010, 09:01 PM »
Vinegar, Tesco's own value stuff 16p a pint
« Reply #2 on: April 01, 2010, 09:22 PM »
lemon juice
smoothblue
« Reply #3 on: April 01, 2010, 09:47 PM »
I use Hammerite rust removal dip,just dilute with water and leave overnight.Available from Halfords and other
outlets. The gel version is not as effective though.
« Reply #4 on: April 01, 2010, 10:17 PM »
Lemon juice OR vinegar Steve - both work well mate  ;)
If you can fully submerse the part into your chosen fluid  :D that's all the better - 24 hours usually does the trick.
However if submersing isn't on the cards then soak loads of paper towels / tissues in your lemon / vinegar and wrap it round the rusty bits and cover up with cling film or foil to keep it moist for 24 hours or more  ;)
If there's a few stubborn bits afterwards then go for the foil technique - scrunch up, dip in lemon juice / vinegar and rub a dub dub - does the trick and a bit more subtle than flatting it off as the alluminium foil is softer than the chrome so it won't scratch it, but it forms a light abrasive compound as the foil breaks down into little speckles and it's enough to get rid of the rust.
Swivel did a great job on a frame using foil and coke and did a cool thread, and i've done forks with lemon juice and foil and a few seat guts etc. using lemon juice or vinegar submersion with a few threads on results too - have a search and post some pics of yer results  :daumenhoch:
sweetbeats
« Reply #5 on: April 01, 2010, 11:56 PM »
SBD
Offline Gary72
« Reply #6 on: April 02, 2010, 09:22 AM »
Pic of drop outs in vinegar
m1ke
« Reply #7 on: April 02, 2010, 06:26 PM »
how good is the wrapping method on a pitted frame ??
« Reply #8 on: April 02, 2010, 07:28 PM »
Just put in as Gary above  ;) drop outs in 2  tubs  :daumenhoch: Wait and c the results  ::)
Offline Dingobmxer
« Reply #9 on: April 02, 2010, 07:51 PM »
Hammer and bolster chisel, works for stickers too  :daumenhoch:
Dingo
Offline Gary72
« Reply #10 on: April 02, 2010, 10:53 PM »
I did a set of pitchforks the other week, Put the steerer tube in to get to the welds on the forks. When I lifted them out the star fangled nut had disentergrated and fell out in pieces :daumenhoch:
Rooonga
« Reply #11 on: April 03, 2010, 03:13 PM »
What vinegar Gary?
Offline Gary72
« Reply #12 on: April 03, 2010, 03:34 PM »
What vinegar Gary?
Tesco's value stuff 4% acidity
UKBMXER1
« Reply #13 on: April 03, 2010, 03:39 PM »
COKE AND TIN FOIL  , DOES HAVE TO BE COCACOLA AND NOT THE CHEAP brand though , i promise you this is the best rust remover going and i have tried the rest.
Deano
« Reply #14 on: April 05, 2010, 12:52 PM »
I used Coke  foil on his
end result which i was totally happy with and much better than having powder'd over
