976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 23, 2026, 04:08 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  2k paint in aerosol cans?
Author Topic: 2k paint in aerosol cans?  (Read 10952 times)
« on: April 05, 2006, 01:12 PM »
can you get 2 pack paint in aerosol cans?
celly rattle cans are ok but the paint is so piss thin and chippable
retrorider.u.k
Re: 2k paint in aerosol cans?
« Reply #1 on: April 05, 2006, 01:25 PM »
good motor factors with mixing station should do it .
Offline diesel
« Reply #2 on: April 05, 2006, 01:39 PM »
YUP:
There's a mixing shop just up the road from me that will do any colour and then put it into spray can for a little extra.
« Reply #3 on: April 05, 2006, 01:41 PM »
i am after base and clear, and primer
i will try and find a local paint shop that will do it!
thanks guys
« Reply #4 on: April 05, 2006, 01:41 PM »
autopaint international, mix any colour in a can, lovely wide full arc on the spray too.
Offline kdw712
« Reply #5 on: April 05, 2006, 02:04 PM »
cool site esp liked this page
http://www.autopaintinternational.com/colourpicker.html
any one gonna do a how to on frame respray at all ?
prep methods, cleaning, base coats, final coats etc
whats good, bad, easy, hard etc
cos i aint ever done that sort of thing before and have a couple i would like to have a go at
cheers Kev
« Reply #6 on: April 05, 2006, 09:05 PM »
i worked for autopaints as a paint mixer bitd lol
Offline Rombloke
  • do one
« Reply #7 on: April 05, 2006, 10:07 PM »
get the proper breathing aparatus graeme.....2 k contain cyanide mate
that fooking stuff kills ya.....
Dave
haro, how do you do
missfitsat101
« Reply #8 on: April 05, 2006, 10:16 PM »
you can get  solvent based basecoats and single pac laquer in aerosols guys but not 2 pac as thes are activated with a hardener  and  goes solid after a couple of hours
solid colours in aerosols arent 2 pac either as these are activated the same  in 2 pac
and once activated  have a couple of hour shelf life
if you give me a bit of time guys i will try and put together a how to paint your frame if you like   with  a prep guide  that can be used  for aerosols as well as 2 pac  :daumenhoch:
missfitsat101
« Reply #9 on: April 05, 2006, 10:29 PM »
graham ici  do an etch priming aerosol  which is an excellent  product  will post up a pic and number   tomorrow :daumenhoch:
Offline kdw712
« Reply #10 on: April 05, 2006, 10:42 PM »
please  :daumenhoch: cos i know i is a junior apprentice novice to paint spraying  ::)
cheers Kev
« Reply #11 on: April 05, 2006, 11:33 PM »
Dave
its the hardener
its n a s t y
missfitsat101
« Reply #12 on: April 05, 2006, 11:44 PM »
http://www.bhopal.com/
just remember the 2 pac is isosienate   we have to wear full face air fed masks cos it will burn your lung lining  so be carefull with it       remember what it did to all these peeps and that is the same stuff but in gas form  not nice   so always wear charcoal filter masks even with aerosols  as cellulose is not good for you if you breath it in
PAINT SAFELY [/color]
« Reply #13 on: April 06, 2006, 06:05 PM »
is that the bad stuff in the touch up paint you gave me craig.
the clear stuff.
im scared now  :o.
missfitsat101
« Reply #14 on: April 06, 2006, 08:10 PM »
yeah dave    :LolLolLolLol:
making up and using as touch up is ok dave its when its atomised through a paint gun is when it is nasty   :daumenhoch:      well as long as you dont start drinking it  :LolLolLolLol:
gjs
« Reply #15 on: April 06, 2006, 10:41 PM »
I used 2k in a can on my gjs replica,turned out ok
