976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 07:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile Box Cranks Spacer - should there be any play?
Author Topic: Profile Box Cranks Spacer - should there be any play?  (Read 1789 times)
Offline Kaner
So I'm just installing these anniversary cranks into a TA and there is half a millimeter play on both sides of the crank arms. I have put 3 large spacers on the non-drive side and 1 large spacer on the drive side next to the spider.
Should there be any play, there is currently half a millimeter play on each side? Not sure if it will cause a problem or not?
I will put some photos up when I can.
Cheers Ben
Re: Profile Box Cranks Spacer - should there be any play?
« Reply #1 on: May 30, 2010, 08:41 AM »
This might help dude, they are exactly the same in terms of the help guide  :daumenhoch:
http://www.profileracing.com/ht_crank_install.php
« Reply #2 on: May 30, 2010, 08:57 AM »
tickler, i mean diggler is just so damn bloody helpful, i think hes great  :daumenhoch:
Bettyswallocks
« Reply #3 on: May 30, 2010, 08:59 AM »
There shouldnt be any play, sounds like you need more spacers
You could wreck the splines if you ride with the arms loose
Bettyswallocks
« Reply #4 on: May 30, 2010, 09:07 AM »
Might be wrong but did the cranks come with any cone spacers?
If not and its for a rider just get a hop up kit, comes with everything you'll need
http://www.alansbmx.com/product_info.php'manufacturers_id=47&products_id=2450
Shop around though cos that seems a bit steep
Offline Kaner
« Reply #5 on: May 30, 2010, 10:50 AM »
Cheers Diggler
Good website.  Now installed the extra small washer on the drive side and it has centred the chain and tightened the crank spot on.   :daumenhoch:
It now has:
Drive side: 1x small washer, 1 x large washer and the spider.
Non Drive Side: 3 x large washers.
I like the look of the cone spacers, washers just look a bit cheap, might see if I can get some of them, not sure if I want to change the colour of the BB though especially at that price??
Thank for all the help boys   :4_17_5:
