976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 06, 2026, 07:14 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Shine Side Rims.
Author Topic: Shine Side Rims.  (Read 2963 times)
Offline Macmania
Shine Side Rims.
« on: June 01, 2010, 02:01 PM »
What is the best method for removing the anno from a wheel rim to create a shine side without making a balls up of the anno on the inside of the rim ? Thanks  :)
Wanted: Anything MT Racing
Weeksy
Re: Shine Side Rims.
« Reply #1 on: June 01, 2010, 02:23 PM »
I would say start  with 800 quid wet and dry on a rubbing block, to minimise the risk of going over the 'corners', then go up to 1000 grit, 1200, then 1500
Weeksy
« Reply #2 on: June 01, 2010, 02:24 PM »
Flap wheel sander or a flat sander  :daumenhoch:
trasher
« Reply #3 on: June 01, 2010, 08:11 PM »
put them on your bike , and ride it with your brakes on ,,,should give you a good start  :coolsmiley:
sid1972
« Reply #4 on: June 01, 2010, 08:16 PM »
 ::)   that would work..  ;D
as other have said mate, tape the inner edge off and flat..  :daumenhoch:
trasher
« Reply #5 on: June 01, 2010, 08:21 PM »
id say go with something more corse than 800 or you will go through boxes of it and get no were, start with 240,320,400.500,600,800,1000,1200,1500,2000 and finish off with a 3000 avlon pad then loads of autol sol and wiz a buffing macining round it,  :smitten:
 :smitten: chinwheel used same principle  :smitten:
fook off costa ,,,that chainrings made out of clear perspex  :2funny:
daz bmx it!
« Reply #6 on: June 01, 2010, 08:30 PM »
costa that chainring is seriously off the hook mate :4_17_5:
Offline double chevron
« Reply #7 on: June 01, 2010, 08:35 PM »
Obviously made with an old CD, not metal  :D
« Reply #8 on: June 01, 2010, 08:54 PM »
its quite clearly computer generated :crazy2:
« Reply #9 on: June 01, 2010, 09:52 PM »
That explains why I got no response to my wanted thread ... ''Block paved chainring 44T wanted''  :D
Them rims and chainwheel are untrue mate :4_17_5:
Nath , Mr costa is right imo , you want to start with something a bit coarser than 800's , use a sanding block like weeksy said too to keep it flat  ;)  I can see a resto thread ' before and after' here Nath  :daumenhoch:
« Reply #10 on: June 01, 2010, 10:20 PM »
nath you need a sawzall
« Reply #11 on: June 01, 2010, 10:29 PM »
I reckon more like a PM coming your way Joff asking you to do it for him  :LolLolLolLol:
« Reply #12 on: June 01, 2010, 10:59 PM »
Very busy with goose bits at the mo John  ;)  :D
« Reply #13 on: June 01, 2010, 11:00 PM »
Well if you are they're not mine  :yahoo_silent:
You gave me most of my stuff last week  :LolLolLolLol:
« Reply #14 on: June 01, 2010, 11:07 PM »
 ::)  The best is yet to come  ;)
Offline Macmania
« Reply #15 on: June 02, 2010, 02:57 PM »
Had no internet for the past 24 hours  >:(
Anyway...........thanks for the replies guys, i'll give it a go  :daumenhoch:
Joff...........got a job for you  ::)   :LolLolLolLol:
