976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 08:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  how to prep for ano - advise needed?
Author Topic: how to prep for ano - advise needed?  (Read 4277 times)
Offline 20to26
« on: June 16, 2010, 11:20 AM »
What's the best way to prepare brake levers for re-anodising?
Should I sand down the scratches with 1500 grit wet & dry?
Offline 20to26
Re: how to prep for ano - advise needed?
« Reply #1 on: June 17, 2010, 09:20 PM »
thanks Glen, is this the case generally?
Offline Haro82
« Reply #2 on: June 18, 2010, 09:23 AM »
I got some suntour beartrap cages redone. I prepped one of them and they did the other.
I wish I had got them to do both  :-[
Offline 20to26
« Reply #3 on: June 25, 2010, 09:38 AM »
I need a pair of levers and calipers done - I see in this pic that the levers seem to have been done with the pivot pin still in - I'm presuming that that's not a problem then:
As for the calipers - the little steel bit at the top of the arm has been removed - how the heck do you get that sucker out?
Offline Haro82
« Reply #4 on: June 25, 2010, 12:21 PM »
That is usually nut/bolted in isn't it ? Do you not just undo it?
Offline 20to26
« Reply #5 on: June 25, 2010, 02:56 PM »
the ones on the DC calipers seem to be pressed in
« Reply #6 on: June 25, 2010, 03:05 PM »
Use a gentle persuader and tap it out with a hammer. I cant see pics so just guessing you are referring to the cable lock bolt.  :daumenhoch:
Offline 20to26
« Reply #7 on: June 25, 2010, 03:26 PM »
the steel bit on the top arm that the cable tensioner screws into
« Reply #8 on: June 25, 2010, 03:27 PM »
Is it an MX900/1000?  CCA cover the steel rivet with a special tape  :daumenhoch:
My 890/1020 has a bolt in adjuster  :-\
« Reply #9 on: June 25, 2010, 04:13 PM »
Post us a picture a picture paints a million words :daumenhoch:
Offline 20to26
« Reply #10 on: June 25, 2010, 04:21 PM »
« Reply #11 on: June 25, 2010, 05:10 PM »
I think it is riveted on . Take a drill to it and take your time, increase the drill size and you will get there. Start with a small drill and work up in size,  There is an oval hole so it might be worth buying one form the local bike shop so that you know what tou are trying to achieve.  the replacement will be bolt on.
Method two is to file the back off the rivet :daumenhoch:
Hope this helps
« Last Edit: June 25, 2010, 05:35 PM by brettypeeps »
Offline 20to26
« Reply #12 on: June 25, 2010, 07:57 PM »
Thanks that sounds like a good approach. I'll try that on one and hopefully get it right first time lol
« Reply #13 on: June 25, 2010, 10:38 PM »
If you are not happy with doing  it send it to me I will do it for you.  I have had over 20 years experience and will take me no time at all.  Lmk :daumenhoch:
« Last Edit: June 26, 2010, 01:34 AM by brettypeeps »
