976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 04:42 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset issue.
Author Topic: headset issue.  (Read 1754 times)
headset issue.
« on: July 26, 2010, 10:34 AM »
hey everyone
just fitted a NOS Nikyo headset to my ride for MK and realised that there is a fair bit of fork between the grip nut & locking nut. now i havent used a spanner on the locking nut yet cus i just need to know if i needed some more spacers between it all or just use a spanner and tighten the locking nut down to the grip nut leaving the excess fork showing. please let me know. cheers.
Offline 20to26
Re: headset issue.
« Reply #1 on: July 26, 2010, 10:35 AM »
I've had this same issue on one of my Kuwahara's - just use headset washers to fill the gap. I used some from a couple old headsets.
Re: headset issue.
« Reply #2 on: July 26, 2010, 10:37 AM »
im sure i've got some but i think it means having to rob some off my rides  >:(
Offline 20to26
Re: headset issue.
« Reply #3 on: July 26, 2010, 10:40 AM »
try an older LBS - they'll have em laying about for sure
Re: headset issue.
« Reply #4 on: July 26, 2010, 10:59 AM »
used some NS 1" 1/8 spacers ;) they do the trick! ;D the locking nut is big so it covers them perfectly and they dont move around :)
Re: headset issue.
« Reply #5 on: July 26, 2010, 11:09 AM »
you may find they do in time though and the headset will always work lose as a result, Halfrauds will have some if you can't find any local shops with them  :daumenhoch:
Re: headset issue.
« Reply #6 on: July 26, 2010, 11:35 AM »
cheers rob :) i'll get rid of the 1" 1/8 spacers and try get some 1" ones plus they kinda stick out like a sore thumb anyways :-\
Re: headset issue.
« Reply #7 on: July 26, 2010, 12:02 PM »
failing that Zac, i'm sure some of us will have some knocking about we can give you at MK, then just change them there  :daumenhoch:
Re: headset issue.
« Reply #8 on: July 26, 2010, 12:04 PM »
cheers bud :daumenhoch: will be good if some of you could lend us some or i'll buy them off you :daumenhoch:
ozone
Re: headset issue.
« Reply #9 on: July 26, 2010, 02:08 PM »
Is it a freestyle bike?  Some freestyle forks are longer so you can install a gyro (the old Odyssey type).
I had this trouble once before...  I got my hacksaw out and cut of the excess steerer - problem solved.   :crazy2:
Re: headset issue.
« Reply #10 on: July 26, 2010, 07:13 PM »
i found a couple of old headset washers so come and see us on saturday Zack  :daumenhoch:
Re: headset issue.
« Reply #11 on: July 26, 2010, 10:15 PM »
pervert
